Quoted from canea:Maybe I need to adjust how the autoplunger is set up then, not sure. Here's a picture of my plunger fully depressed. So while it is contacting the ball, it's a pretty weak plunge. Sorry for the crappy picture. Shooter lanes have to be one of the hardest things to photograph...
From your picture it looks like your plunger is aligned a little to the right.
Your Cliffy protector might also be the culprit, I can tell from your pic that the ball is hitting it. Right after I installed mine the ball was bouncing out of the lane on to the playfield, if it would even get out of the lane because of weak launches. I loosened the screws and made sure it was as far in as possible over the trough, problem solved.
There was never a problem with auto-launches though, so the plunger rod must be a little off-center on some.
Quoted from RonB:Your Cliffy protector might also be the culprit, I can tell from your pic that the ball is hitting it.
This is exactly it. Took the Cliffy out and it plunges straight and strong. Guess I need to file the Cliffy down or just leave it out. Gave up on the Cliffy under the rail - this one might go that way too. Thanks all!
Quoted from YKpinballer:From your picture it looks like your plunger is aligned a little to the right.
I wonder if that explains the left cliffy getting beat up as well.
Ive had the eject hole cliffy on my met for a year now and habent had any issues. I do think mine was mounted a bit further back. I can take a picture if you think that would help.
Have bricking drops been an issue? Since shopping mine I've been getting solid shots to the drops (more than just the front one) rejected with no drop. The only difference I can think of that I caused was cleaning the flipper mechs and replacing nasty coil sleeves when in combination with waxing has resulted in significantly higher ball speeds. I didn't mess with that mech at all, nor have I inspected it since I noticed the problem. Thinking possibly its gotten loose and shifted back?
Curious if this is a known issue with a solution. I'll get to popping the hood on mine in a day or two.
I got a few bricks for a while after I cleaned my playfield too. I think it is just the faster ball speed, they diminished after a while. I'm due for another cleaning so I'll pay attention to the bricks afterwards again.
Quoted from btw75:The only difference I can think of that I caused was cleaning the flipper mechs and replacing nasty coil sleeves when in combination with waxing has resulted in significantly higher ball speeds.
Waxing a newish playfield will increase ball speed and reduce ball rotation. Both of those things will increase bricked drop target shots. You can either wait until the wax wears off or remove it.
Working on a custom shooter rod for my Metallica. Bought a miniature skull from some Thailand eBay shop, sculpted an electric chair helmet and eyes out of Kneadatite, and gave it all a paint job.
Need to clear coat it and buy a new blank shooter rod from Terry, it's on the back side of an existing one for the pic.
Quoted from freddy:needs a tongue ! LOL looks cool.
I did consider cutting the jaw and resculpting it so it was open, but since this is something that will get grabbed and pulled on I decided to not make it structurally weaker, or risk making it to uncomfortable to hold.
Quoted from YKpinballer:Looks awesome. Would love one of those.
If anyone wants to try making their own here's the skull I started with:
Hi all, prem./L.E. owners, I'am getting bounce backs on the left spinner. Shoot the ball at the left spinner and it bounces back making a "clunk noise." Now, The spinner itself at rest, is not straight up and down, kinda tilted up at the bottom. I checked some of your photos and other Prem./ L.E.'s machines, and all seem like mine. Just wonder if this is normal, happens every game the left spinner rejects the ball, and of course sometimes it doesn't. Normal?
I also have a MDM display for sale if anyone is interested, $75 shipped
Quoted from Aurich:Working on a custom shooter rod for my Metallica. Bought a miniature skull from some Thailand eBay shop, sculpted an electric chair helmet and eyes out of Kneadatite, and gave it all a paint job.
Need to clear coat it and buy a new blank shooter rod from Terry, it's on the back side of an existing one for the pic.image-844.jpg 102 KB
image-459.jpg 87 KB
image-419.jpg 92 KB
This is the best MET shooter rod MOD I've seen so far....nice touch man!!
Quoted from Pinballerchef:This is the best MET shooter rod MOD I've seen so far....nice touch man!!
Thanks, I'll take install pics once I get around to ordering a blank rod from Terry.
Mirror blades from CoinTaker installed tonight. Used a couple of 4" ratcheting bar clamps to hold them in place from HF while I installed the blades:
http://www.harborfreight.com/4-in-ratchet-bar-clampspreader-68974.html
It is definitely a tight fit between the PF edges and the mirror blades. I highly recommend utilizing vacuum caps on the rollers underneath the PF to keep the blades from getting damaged. Please see this post to get a visual on what I am referring to:
https://pinside.com/pinball/forum/topic/metallica-owners-thread/page/31#post-2031718
Mirror blades look badass. These suckers are as hefty as saw blades. Definitely built to last in terms of durability. The mirror surface will definitely keep me lifting and lowering my PF verrrrrrryyyy slowly...
Does the Pro not come with spotlights on the slingshots? Never noticed before, but see they aren't in that shot.
Quoted from Aurich:Does the Pro not come with spotlights on the slingshots? Never noticed before, but see they aren't in that shot.
i guess they are needed to light up that HAMMER!
Mine came with them, maybe they moved them/tied them in to something else?
My neighbor has spotlights on his slings. Weird.
Quoted from Jnewton:Mine came with them, maybe they moved them/tied them in to something else?
I kind of want to take mine off, they're pretty ugly, and I don't really think they're all that necessary.
They do. The PO removed them, and I just and never taken the time to re-install. Honestly, so far, I am good without them. I have never noticed they're missing yet !
Quoted from NPO:They do. The PO removed them, and I just and never taken the time to re-install. Honestly, so far, I am good without them. I have never noticed they're missing yet !
I just don't think you need them honestly. I mean, yeah, you see the place they light, but take the bulbs out and play a game and see if you care.
Quoted from Aurich:I just don't think you need them honestly. I mean, yeah, you see the place they light, but take the bulbs out and play a game and see if you care.
Why take them out... when you can simply let them fall out
Quoted from Purpledrilmonkey:Why take them out... when you can simply let them fall out
Because they usually fall in a place where it takes ya 15min. go get it out of AND it's usually during an epic game.
I bent mine to aim down more and they do a really nice job of lighting up the middle section of the playfield away from the GI. I really like the difference it makes.
Got my Sparky air ball deflector from Rick. Works awesome! All those air balls from his feet was one of my pet peeves with the game. I highly recommend this. Thanks Rick!
Quoted from JC_Pins:Is there a good way to keep Sparky's shoes from getting scuffed up?
shine them
image-459.jpg 87 KB
image-419.jpg 92 KB
I picked up the same skull a few weeks ago... Still not sure if I like its placement on mine but a couple of my buddies thought it was cool
image.jpgQuoted from tilted81:I picked up the same skull a few weeks ago... Still not sure if I like its placement on mine but a couple of my buddies thought it was cool
image.jpg 185 KB
I've got some skull and Cobra night lights for sale and am going to put a skull on my Refinery Met Pro. I put a Cobra on my Mustang and tied it into one of the pop lights and it really looks cool. PM me if your interested in a skull or Cobra night light not the mod, you have to mod it yourself. I have a post up on how I built the one for Mustang, the skull would be the same.
Quoted from Rob_G:Argh, the autolaunch on my MET is acting up again! During multiball today it was repeatedly launching balls directly into the right outlane. Yup, flipping them in the air somehow, over the lane guide and down the right oulane. Time to check it out.. again!
Rob
Dang, it's happened before?
Quoted from MustangPaul:I've got some skull and Cobra night lights for sale and am going to put a skull on my Refinery Met Pro. I put a Cobra on my Mustang and tied it into one of the pop lights and it really looks cool. PM me if your interested in a skull or Cobra. I have a post up on how I built the one for Mustang, the skull would be the same.
IMGA0510.JPG 202 KB
IMGA0506.JPG 89 KB
IMGA0504.JPG 130 KB
IMGA0505.JPG 301 KB
Just got done with the skull mod on MET Pro and started a topic about the build. I tried to get a picture of it lit up but it's tied into the flashers and impossible to get. Here it is on the game though.
IMGA0531.JPG IMGA0532.JPG IMGA0533.JPGQuoted from MustangPaul:Dang, it's happened before?
Yeah, before it was routinely launching balls into the middle of the playfield from the shooter lane. I adjusted the launcher several times before it seemed to be ok, but something is still wrong. The ball just seems to instantly 'go sideways' in the shooter lane like something was blocking its path. Perhaps the shooter lane switch wire is hanging up and acting like a ramp.. I'll check it again.
As comic book guy might say, worst autolaunch ever!
Rob
Quoted from Rob_G:Yeah, before it was routinely launching balls into the middle of the playfield from the shooter lane. I adjusted the launcher several times before it seemed to be ok, but something is still wrong. The ball just seems to instantly 'go sideways' in the shooter lane like something was blocking its path. Perhaps the shooter lane switch wire is hanging up and acting like a ramp.. I'll check it again.
Rob
Hope ya fix it for good this time.
Quoted from Rob_G:The ball just seems to instantly 'go sideways' in the shooter lane like something was blocking its path.
My guess would be something is, like one of the protectors we talked about earlier, or your rod is crooked.
Rob
If your rod is misaligned to the left, its going to hit the ball and it goes right, hits the right side lane and bounces out.
Quoted from Aurich:Got my blank shooter rod from Terry so I mounted my skull.
image.jpg 85 KB
image-745.jpg 105 KB
At first I wasnt sure about this, but seeing it mounted, BAD ASS great job!!!
image.jpg 85 KB
Looks great but how does it feel when using it?
Quoted from MustangPaul:Looks great but how does it feel when using it?
It's pretty good, the shape fits my hand nicely. A few slightly sharper edges than I'd like, if I did a version two I'd sculpt the bottom to smooth that out, and also add some weight to the bottom to keep it from wanting to turn. I'm happy with it for now though, so we'll see if I feel motivated to do another one later. Working on another Metallica project now, so definitely won't worry about it until I'm further along with that, I'm bad enough as it is with starting multiple things at once.
Quoted from Aurich:Working on another Metallica project now,
Looking forward to see what you're cooking up.
Quoted from Aurich:Working on another Metallica project now, so definitely won't worry about it until I'm further along with that, I'm bad enough as it is with starting multiple things at once.
Another Metallica project, eh? Do tell.
Quoted from epthegeek:Another Metallica project, eh? Do tell.
Still working it all out, but I'll say it's not a translite.
This page was printed from https://pinside.com/pinball/forum/topic/metallica-owners-thread/page/35 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
