Quoted from Rob_G:Is anyone seeing airballs off the captiveball? I replaced the block and on dead on shots the ball seems to hop up into the back of the hammer quite often. Some other shots ricochet over the grave markers into the left orbit which has never happened before.
I put a 1mm washer under the captive ball and still saw airballs. I'm going to put the block back in.
Edit #2. I put the block back in. I think there's still slight airballs into the hammer, but at least there shouldn't be any more into the left side of the playfield.
Rob
Not one. I don't think I've ever seen an airball off the block or the ball.
Is your magnet plate level and not sitting high? Do you have the cliffy ring installed? I would expect those to maybe cause airballs a bit.
