Quoted from WesleyCowan:Okay took out PSU and it tests fine. Reseated every connector and put new RAMs in CPU. Also redownloaded software for game.
Not it turns on including monitors, leds on fuses and all the lights and monitor is showing in attract mode. But start button not lit and it won't start game Nor go into game menu to let me start tests, settings etc.
Found this on I/O board blown.
It is a very small blue one. There are two on the board. But would this allow game to boot up, get to start with monitor in attract mode but then not start game and not allow to get into menus abd tests? I didn't have time to replace it yet, but wondering.
Capacitor, MLCC, Leaded, 100nF, 630V, 10
Quoted from pinballinreno:Loose connector for the door switches?
Not set to free play?
Did you backup your settings? Did you try to install your backup settings?
Finally Hobbit is mostly working after putting in a different time CPU and I/O board
Sure was wonderful to have it turn on and hit start and it started after weeks on and off of frustration! Thanks to all who gave suggestions or well wishes!
New problem is now all the pop up mechanisms come up right time in game but go up and down really fast i.e shot gunning. Did the usual check fuses, looked at manual and reseated relevant in the game on I/O connectors. Must be overlooking something.
Since it's all 3 can't believe it's mechanical. Any thoughts on what else to check?
