(Topic ID: 155578)
Hobbit Owners Thread
By Eryeal
7 years ago
16 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 12,037 posts in this topic. You are on page 73 of 241.
#3601 5 years ago
Quoted from Bendit:
Hobbit down!
That rubber was torn from the factory install. It's the one behind the barrels.
bummer... Noticed that JJP's store doesn't have white rubbers?
mine also broke same rubber! no biggie just replaced it.
#3602 5 years ago
Quoted from Bendit:
Hobbit down!
I ordered my replacements from https://www.titanpinball.com/ - but I got clear (not white). And replaced them all, and got a few extra rings and flipper rubbers (which I do green on the bottom and red on top right flipper)
#3603 5 years ago
I also installed the cliffy protector kit for the hobbit - as well as switch protectors for inlanes and windlance lane.
#3604 5 years ago
Quoted from Goronic:
interesting idea! Thanks!
Good work. Wondering if I should do that too.
#3605 5 years ago
Quoted from freddy:
It's no biggie if you have a replacement on-hand. Without this rubber, the ball always gets stuck behind the pops.
Boondocker might hook me up tonight with one of his spares!
#3606 5 years ago
Quoted from Bendit:
By they way - there reason I went with transparent (clear) rubbers was 2 fold:
1. It doesn't appear to show grey/black residue on it as bad as white does. Looks cleaner longer.
2. It makes the lights look better when it shines on them (to me)
I also switched the black post rubbers to clear as well because the black rubber (as it ages and wears) will come off and on to the play field. The clear will do that but harder to see (so cleaner look). I still go in a wax and clear the PF every month or so to keep it nice and shiny and free of debris.
#3607 5 years ago
Quoted from Bendit:
I think they add good protection - and I think they look cool to boot. (more metal on the PF looks nice to me - within reason of course.)
#3608 5 years ago
Sold!
Did you buy a "kit" or a bunch of them separately?
#3609 5 years ago
Quoted from Bendit:
That will learn ya! Be prepared mama was right.
#3610 5 years ago
Quoted from Bendit:
Hobbit down!
That one breaks on mine all of the time. I try to rotate it when it starts to tear. I still cannot figure out what is causing it to tear though.
#3611 5 years ago
Quoted from crwjumper:
Maybe the side of the leaves from the switch?
#3612 5 years ago
Quoted from Bendit:
Sold!
I got this for the cliffy.
http://www.passionforpinball.com/hobbit.htm
For the rubbers I went into the manual and ordered the sizes they have listed. Got a few extra like 3/8 inch IDs and stuff. Ordered them separately.
http://docs.jerseyjackpinball.com/the-hobbit/Hobbit_Manual_3_0_Dec_2016.pdf (C-104 and C-105)
#3613 5 years ago
Quoted from elf70:
For some reason, Victor @ JJP suggested I use the loctite on screws that were holding in the drop target banks to the bottom of the playfield that were coming loose. I was going to do the same on my beast head screws that keep coming loose but he also in the same message specifically said not to use the loctite on the beast head screws, only the drop target banks.. and I am not sure why.. any ideas?
If you are settting screws into the playfield plywood itself use titebond III. If the hole is stripped put a piece of toothpick or bamboo skewer in the hole with glue and set the screw.
Metal on metal screws should be installed with loctite blue.
The character heads keep coming loose without the addition of some type of removable adhesive.
Loctite "blue" or permatex "blue" will hold the screws tightly and still allow you to remove them as needed.
Im using loctite blue all over the place on my games.
As soon as I see a screw come loose from use or vibration I just add a couple drops of blue loctite to them and re-install. The problem usually goes away.
Be aware that there are many colors of loctite and permatex adhesives.
Each color corresponds to the level of adhesion. Blue and purple are designed for removable applications.
Never use red adhesive on a pinball game. You will never get the screw out without applying heat.
#3614 5 years ago
Thanks Goronic! Awesome info.
#3615 5 years ago
Finally got the barrel lamp mods all installed. They look awesome!
#3616 5 years ago
Quoted from FlippyD:
They do look nice - I may get those as well. Can you take a quick pick holding the original spotlight next the barrel for scale? I am worried that if it is too large it would block too much of the playfield.
#3617 5 years ago
What did you guys use to diffuse the backglass light? Anything local at Menards or home Depot?
#3618 5 years ago
Quoted from mima:
I cooked up these decals for the dwarf stand up targets. What's your opinion?
Cheers
/mima
Here is an reference image to see what the decals actually look like in context to what they look like photographed applied to my friends H-LE by my friend...
Cheers
/mima
#3619 5 years ago
I finally killed smaug last night!!! What an amazing sequence. I just love this game.
#3620 5 years ago
Sorry already reused the spots in another game! But they don't block much more than the original spots did. Maybe a tiny percent more but not enough to feel like they are obscuring things.
#3621 5 years ago
Quoted from konghusker:
Congrats,I'm still looking forward to my first time
#3622 5 years ago
Quoted from Wildbill327:
Thanks. Took me a year, but worth it. I watched a how to video to understand, but stopped it short so it didn't ruin the show for me. What a great game. Now hoping for one final wizard mode to be added, and I'll feel like the game is done.
#3623 5 years ago
I'm still working on that.
#3624 5 years ago
I would love to see a pic that shows the overall effect
#3625 5 years ago
Quoted from pinball_keefer:
Default settings actually spot 1 for you at ball start, but that was changed later so you may or may not have that set.
All 6 have to be lit at once. Other than that, after you get it, ou do have to earn all of them again, meaning you have to use them up first.
Well, I did have one spotted at start. Changed the "Mode Difficulty" to 5 instead of 4 and that made it do none are spotted at game start. What do the higher difficulties do for that option?
If you are a perfectionist like me Keith...there are a few inconsistencies in the capitalization in the game settings menu. They're easy to spot.
Also, I started the mode "The Bait" and then immediately started "Battle of 5 Armies"...and The Bait kept going during 5 Armies! Is that right? It died out after the mode timer ended, but didn't seem like it should be active. Same with reaching Erebor and starting an Arkenstone mode. The super spinner stays active.
#3626 5 years ago
Excuse my ignorance if this has been spoken of already. I have a Hobbit LE on location and I am experiencing these mechanical issues (see pics). The drop target coil stop studs and drop target "latch edges" are breaking away. I can epoxy the edges back no problem and they hold, but the studs are pretty much sheared off and unfortunately, welded to the frame.
I have already called JJP and they have sent over new DT mechs, but I know this will happen again as the machine in question gets A LOT of play.
Has anyone had a machine/weld shop re-weld studs to the frame ?
Thanks to any reply.
#3627 5 years ago
Question: How do I "earn" the Golumn ring save?
What does the target on the lower right outline do?
Thanks guys, I've had a few theories, but still don't quite get what's happening.
#3628 5 years ago
Quoted from Pinball-Pat:
I believe Gollum Ring Save is lit by getting your Mystery target to level 4 and then hitting it.
The Beorn target in the lower right outlane is an "add-a-ball" if hit during a Multiball and the inlanes lights are strobing in a sequence towards it. The target has nothing to do with Smeagal/Gollum.
#3629 5 years ago
Ring save is a mystery award. The lower right outlane target adds a ball during multiball modes.
#3630 5 years ago
It's my favorite Mystery. It's awesome. Love the movie sequence on the LCD too.
#3631 5 years ago
Quoted from Bendit:
Agreed. Also like the challenge of avoiding the mystery target to build the mystery award.
#3632 5 years ago
Quoted from Jvspin:
Agreed. Except I hit all over the place when Smaug multiball starts. I'm like a large mammal in a pinball shop...
#3633 5 years ago
How do you build the mystery and how do you know what level you're on?
#3634 5 years ago
Quoted from mima:
Cheers
/mima
I like these! Can I purchase a set?
#3635 5 years ago
Quoted from wolv3:
If I remember correctly, look at the color of the triangle shaped inserts on the ball guide just before the flippers.
They start out flashing blue. When you go down an inlane the color will go solid on that side. When you go down the other side, the mystery shot will light with that color, ie. blue for the first level, and the triangle inserts will advance to the color of the next level award and start flashing again.
Each time you go down a left and right inlane without hitting the mystery shot, the color will advance until you get to solid green on both sides which lights the mystery shot for the gollum ball save award. I believe it's the fourth level.
Hitting the mystery target gives the current award and resets the triangle inserts back to flashing blue.
#3636 5 years ago
Quoted from netman63129:
Send me a PM and we'll work something out.
Cheers
/Micael
#3637 5 years ago
Quoted from MarcelG:
I have had to replace two banks - just due to this. I hope JJP will correct and make those more resilient and allow existing mechs to be refurbished for a reasonable price
#3638 5 years ago
With the code 2.00, the game is amazing.
For me it takes 2 more things:
-a grand finale (after completing the 31 modes, the 3 mini wizard mode, shoot down the dragon)
- get harder access to the mini wizard mode: example (in addition to multibead beast, ereaborn ,,): for the 1st mini wizard mode obligation to complete 2 modes; For the 2nd: obligation to finish 4 modes; For the 3rd: obligation to finish 6 modes
#3639 5 years ago
Quoted from sebseb12:
I think the 'arrows' that light up when you complete should go to 2 for the next one, and 3 for the BOFA. It would look cool on the backglass monitor and simple to understand. Perhaps to get the final mode you would also need to kill Smaug.
#3640 5 years ago
Do you think that the code with the grand finale will be published this year?
#3641 5 years ago
When I upgraded my machine to version 1.90 I didn't have a clue what I was doing. Now it is time to attempt to install version 2.0. I notice on JJP website there is a download for "Hobbit Change Log version 2.0". Am I suppose to install this too or just "Hobbit Change Install Ver.2.0 (USA mirror)"? Thanks for any advice.
#3642 5 years ago
Quoted from fordtudoor:
No. That just tells you what was changed in the update.
Just download and install this one - The Hobbit Delta Install Ver 2.00 (USA Mirror)
#3643 5 years ago
I don't think jjp will let us down with code,up dated woz after 4 years so I am sure we will get more code
#3644 5 years ago
Anybody have mirror blades for The Hobbit?
I have blades in all my games, except The Hobbit...
#3645 5 years ago
Quoted from Bendit:
Get them from cointaker. Have them in mine. They are the same ones used in bw games.
#3646 5 years ago
Like these?
http://cointaker.com/products/copy-of-stern-dmd-mirror-blades
(why are they called DMD mirror blades? What does the DMD have anything to do with cabinet mirrors????)
#3647 5 years ago
Hello,
Is there a summary of the rules following code 2.0?
#3648 5 years ago
no mirrors but...
#3649 5 years ago
Quoted from mima:
no mirrors but
These are nice!!!! Where are they from? Is it a sticker/decal?
#3650 5 years ago
I've noticed, changing from "Free Game" to "Points" in the setup, Gandalf will still scream FREE GAME! during a game.
Precision Pinball prod.
Flipper parts
This page was printed from https://pinside.com/pinball/forum/topic/hobbit-owners-thread/page/73 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
