Quoted from Jeff_PHX_AZ:What made me look closer at this, was because of the ball coming right back at the flipper when the shot is made up there .Can you all check left ramp and ball guide there on left side/ If you look in the pic's you can see the issue. It must have been installed like this from factory, I only had this game since July, about 200 plays or so. That guard rail is bent all the way down. Tried bending with fingers but she not budging. No way ball strikes did this on such little plays. The edge of ramp is getting direct hits and is starting to get bashed.
1911881_10202497860957553_452408... 65 KB
10171850_10202497861637570_46992... 55 KB
Just looked at mine and it's straight up and down. Lift the pf and see if it's bolted on, if so you should be able to remove and straighten it. I can't get at my game to check. If you can straighten it and put it back in I'd change all the balls, they are probably pretty banged up which is not good for the pf.
