(Topic ID: 225496)
Stern Electronics Club (1977-1984).
By Mitch
5 years ago
  • 10,776 posts
  • 443 Pinsiders participating
  • Latest reply 38 hours ago by Biju
  • Topic is favorited by 245 Pinsiders
11 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 10,776 posts in this topic. You are on page 19 of 216.
#901 5 years ago
Quoted from dasvis:
Nice write up, thanks
Thanks. I have a correction in instructions that need attention. If you decided to use this replacement pivot please be advised as follows:
Be aware that Stern was not all that precise on how parts were located on the play field. Position the replacement pivot with the one hole that I highlighted as being the only hole that matches the original pivot. When you proceed to line up the replacement pivot, try as much as you can to align the replacement on the same angle as the original.
When I was doing my repair yesterday on my Nine Ball, I filled to two original holes and drilled two new holes. However, I lined the pivot shaft to be perpendicular to the cutout in the play field instead of matching the original imprecise alignment from the factory. The result was that I now had to relocate the coil bracket (drill 3 new holes). I felt this was my only option because I did not want to realign the new pivot which would have met plugging the new two holes I had drilled and drilling another two holes.
#902 5 years ago
Dracula..... coming back to life as it were....
More pics in following days/weeks....
IMG_2037 (resized).jpgIMG_2037 (resized).jpgIMG_2039 (resized).jpgIMG_2039 (resized).jpgIMG_2047 (resized).jpgIMG_2047 (resized).jpg
#903 5 years ago
Quoted from WeatherbyMAG:
How many coats of clear do you have on? It looks nice.
#904 5 years ago
Adjusting your inlane/outlane ball guides. I won't ask the rhetorical question.
I like fast flipper action. I like the sword fight with the flippers that happens on a fast machine.
I like to adjust my inlane guides to one-half ball height at the entry point and at the exit point in front of the flipper. We use 1 1/16" balls so 1/2 is .55 inch. At mid-point I pull the guides up to .80 inch above the play field.
I try to illustrate with this pic but you cannot easily see what I am talking about. I don't have any engineering on this. It is WAG. My logic is the ball exits into the inlane at speed and as it moves down the guide at the point in the curve (middle pic) where I have the guide lifted up to .80 high the ball sort of slides under the guide just a little. And then as the ball proceeds on down towards the flipper it enters in the area where the guide starts tapering back down to .55 at the flipper exit point.
As stated, I do not have any engineering but my thought is that the ball does not lose any speed as it rolls towards the flipper. But as it enters the area where the guide starts tapering down from .80 to .55 then the larger diameter of the center of the ball gives the ball a little bit of an increase in velocity which helps the ball to sail by the flipper just a little bit faster.
I have no engineering, but it does not hurt anything, so this is how I like to adjust my guides. Your mileage may differ and you may prefer to have your guides "laying flat" all the way around the curve.
Screen Shot 2019-01-23 at 11.13.41 PM (resized).pngScreen Shot 2019-01-23 at 11.13.41 PM (resized).png
#905 5 years ago
Quoted from cottonm4:
Off top of my head I think it has 8 coats total, but keep in mind it was wet sanded in between every 2 coats, so total finished thickness?
It's hard to get good pics of clear PF's in my garage where I work on them, I have 26 very bright halogen ceiling light fixtures each with 4 bulbs in & they overpower the camera when taking pics, you end up just seeing bright white reflections of the lights.
Next step get all the rubbing/polishing compound out of all the edges & get holes all opened back up & get it ready for assembly.
#906 5 years ago
Let me open up my reference book of profanity. I removed the glass from my Catacomb to take the pics of the ball guides. I did not raise the play field or do anything else. All I did was take the glass off and then replace it. And when I put the glass back on, the ball launcher decided to quit working. I just love trouble shooting this stuff (sigh). &^$##&###^%^U& !!!!!
#907 5 years ago
I have long maintained that pins have personality.
Yours is definitely messin' with 'ya cotton!
#908 5 years ago
Well in that case, this Freefall has TONS of character
#909 5 years ago
Hey guys, quick question here. I have a project dolly parton that has a acid damaged mpu. I have a nice and clean stern MPU-200 that I have laying around and I was hoping to use in for that project. My main question is if this will work if I jumper it right and put the correct roms in? Thanks for any suggestions!
#910 5 years ago
Quoted from Ronnie1114:
If jumpered correct the stern mpu200 works in all stern and bally(pre6803) machines.
#911 5 years ago
It will work, but my motto has always been not to waste a -200 in a Bally. There are too many Bally boards that are floating around.
Jim
#912 5 years ago
From the Throw Nothing Away Dept.
I figured out a new use for those old worn out lamp sockets. The metal is rigid but still soft enough you can bend it all over. You know, you have done this hundreds of times when you replace bulbs.
Don't throw that old lamp away. The metal strap makes great brackets.
#913 5 years ago
Quoted from Gott_Lieb:
Jim
Ok I'm glad to hear it will work! After reading the pinwiki it did seem like a waste. Anyone interested in trading a good -35 board for my mpu-200? It came out of a nine ball it looks like.
#914 5 years ago
What leg bolts came on ths3s from the factory? The smaller 9/16th like classic bally's or the bigger 5/8th.
#915 5 years ago
Flat top (non-acorned) 9/16 is what I have on most of my classic Sterns.
A83B0270-861F-4A48-B3D8-91CD372EA4CC (resized).jpegA83B0270-861F-4A48-B3D8-91CD372EA4CC (resized).jpeg
#916 5 years ago
Quoted from NimblePin:
Yes, I had the same ones on a Wild Fyre and on a Hot Hand that I have now.
#917 5 years ago
Quoted from Alan_L:
From what I have read, & what was on my Original Seawitch, they were just 3/18-16 bolts, with a plain 9/16" sized head (no markings).
#918 5 years ago
Making progress on Dracula....
IMG_2066 (resized).jpgIMG_2066 (resized).jpgIMG_2070 (resized).jpgIMG_2070 (resized).jpgIMG_2071 (resized).jpgIMG_2071 (resized).jpgIMG_2073 (resized).jpgIMG_2073 (resized).jpgIMG_2075 (resized).jpgIMG_2075 (resized).jpg
#919 5 years ago
That is brilliant!!!!!!!!!!!! I have to make the seawitch ball jam plastic thing soon and this will work well I think!
#920 5 years ago
[quoted image][quoted image][quoted image][quoted image][quoted image]
Looking awesome!!!!!!!
#921 5 years ago
Stunning!
#922 5 years ago
Is stargazer the only stern with the extra metal rails under the playfield?
#923 5 years ago
Also what does everyone have there transformer set to? My stargazer is jumpered for 115ac not 120ac and all the coil are really strong.
Tested my wall outlet and its 119ac.
Surprisingly even with all the wire hacks this thing still plays great
20190128_181353 (resized).jpg20190128_181353 (resized).jpg20190128_181414 (resized).jpg20190128_181414 (resized).jpg20190128_182209 (resized).jpg20190128_182209 (resized).jpg
#924 5 years ago
Quoted from Mitch:
No. There seems to be no rhyme or reason as to which ones have the metal rails.
#925 5 years ago
So every stargazer has them or just a few?
Do you have any games with them.
#926 5 years ago
Quoted from Mitch:
Meteor.....................no
Big Game .................no
Cheetah play field.....yes.
Seawitch...................no
Catacomb ................yes.
Nine Ball .................no
Dragonfist.................yes.
I don't know about Star Gazer.
#927 5 years ago
Quoted from Mitch:
The common belief is that they were added to playfields that Stern felt weren’t stable enough, meaning they feared that individual playfields might buckle/sag. People have reported several titles that have the supports,but not every copy of the title does
#928 5 years ago
Quoted from Mitch:
Surprisingly even with all the wire hacks this thing still plays great [quoted image][quoted image][quoted image]
My Lightning was also jumpered for 115VAC. Some of my voltages measured a little high. I changed it to 120VAC and the measured DC voltages are much closer to specs.
#929 5 years ago
My only Classic Stern is Lightning. I bought it as a project. I put about 65 hours into it and about $800 in parts. I recently spent another $120 on a CPR plastic set that I have yet to install. I know this game doesn't get the love of some of the other Sterns, but it has a really unique rule set and I'm digging it. Nothing like ripping the spinner when lit for 1k plus 4x playfield. Hard to set it up but man, 350-400K per spinner rip! I also really like how the bonus maxes at 99k times 5x. That bonus meltdown is sweet!
Here are some before and after pics.
Before:
20180528_173808 (resized).jpg20180528_173808 (resized).jpg20180528_173829 (resized).jpg20180528_173829 (resized).jpg20180528_173853 (resized).jpg20180528_173853 (resized).jpg20180528_173900 (resized).jpg20180528_173900 (resized).jpg20180528_173908 (resized).jpg20180528_173908 (resized).jpgDSCF6903 (resized).JPGDSCF6903 (resized).JPGDSCF6910 (resized).JPGDSCF6910 (resized).JPGDSCF6922 (resized).JPGDSCF6922 (resized).JPG
#930 5 years ago
After:
20181201_201120 (resized).jpg20181201_201120 (resized).jpgDSCF6985 (resized).JPGDSCF6985 (resized).JPGDSCF6968 (resized).JPGDSCF6968 (resized).JPGDSCF6994 (resized).JPGDSCF6994 (resized).JPGDSCF6992 (resized).JPGDSCF6992 (resized).JPGDSCF7000 (resized).JPGDSCF7000 (resized).JPGDSCF7002 (resized).JPGDSCF7002 (resized).JPGDSCF7003 (resized).JPGDSCF7003 (resized).JPGDSCF7006 (resized).JPGDSCF7006 (resized).JPGDSCF7009 (resized).JPGDSCF7009 (resized).JPGDSCF6996 (resized).JPGDSCF6996 (resized).JPGDSCF6961 (resized).JPGDSCF6961 (resized).JPG
#931 5 years ago
Wow! Looks great Chris!
#932 5 years ago
Quoted from LOTR_breath:
Awsome thanks for the insight. I noticed all my voltages were a little high.
#933 5 years ago
Thanks Eric! It was a lot of work and my first attempt at bringing one back from the dead.
#934 5 years ago
I'd love to get a lightning someday
#935 5 years ago
I sell hardly any glass. Lightning must of been a good production run.
#936 5 years ago
Quoted from greatwichjohn:
I might decide to get one from you. Mine has two big scratches and a few bare spots from bulb heat.
20180528_174532 (resized).jpg20180528_174532 (resized).jpgDSCF6990 (resized).JPGDSCF6990 (resized).JPG
#937 5 years ago
Im still hoping you do quicksilver someday.
The seawitch of yours I have is great. Cant wait for my stargazer.
#938 5 years ago
Quoted from Mitch:
Ali - yep
Hot Hand - yep
Lightning - yep
Quicksilver - nope
Stingray - nope
Star Gazer - yep
#939 5 years ago
Quoted from OTTOgd:
Ali - yep
Hot Hand - yep
Lightning - yep
Quicksilver - nope
Stingray - nope
Star Gazer - yep
My Galaxy has them.
#940 5 years ago
Quoted from Mitch:
Stargazer yes
Flight 2000 yes
Nine ball yes
Catacomb yes
Big game no
Iron maiden yes
Viper yes
Quicksilver no
#941 5 years ago
I'm curious if any Lightning owners tried removing the one way gates above the ramps on their game. Lightning left me flat, but I think getting rid of the gates would make a great improvement.
#942 5 years ago
Yes someone mentioned removing one side, can't remember which, but they loved the way it changed the game.
#943 5 years ago
Still hoping for a Magic backglass. Mine looks like ass, and not the nice kind.
#944 5 years ago
Quoted from Mitch:
I have them on my Hot Hand but don't remember them on a Wild Fyre I used to own.
#945 5 years ago
Look what followed me home. DAMMIT!!! I keep trying to make room and they keep following me home lol.
20190129_120220 (resized).jpg20190129_120220 (resized).jpg20190129_120226 (resized).jpg20190129_120226 (resized).jpg
#946 5 years ago
Didn't get rid of that Fireplace for nuthing!
#947 5 years ago
Quoted from dothedoo:
I would assume the right gate more so than the left one. That long journey from the gate to the center hole in the upper PF felt painstakingly long to me.
#948 5 years ago
Quoted from Mitch:
If you you think you might need a play field to replace your Dracula play field, maybe I can help. Don't hesitate to ask if you need a hand
#949 5 years ago
Quoted from Mitch:
Those projects keep piling up. I estimate if you start now, you would be finished in 10 years.
#950 5 years ago
Quoted from SuperPinball:
Looking like 6 years atleast lol. All I have is time. I'm only 33
$ 12.00
$ 319.99
$ 859.00
$ 29.00
RoyGBev Pinball
$ 189.00
$ 55.00
Slipstream Mod Shop
7,275 (OBO)
Tempe, AZ
Cabinet Parts
$ 12.00
$ 33.00
PinballReplacementParts
1,500 (OBO)
Orchard Lake Village, MI
Various Novelties
Pinball Photos LLC
$ 12.00
$ 189.00
$ 169.00
Hardware
Gameroom Mods
2,182 (OBO)
Fort Myers, FL
$ 859.00
$ 12.00
Melbourne Beach, FL
$ 169.00
This page was printed from https://pinside.com/pinball/forum/topic/price-check-1980-sterns-quicksilver-stargazer-seawitch/page/19 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
