So I have my new premium in and have been working to dial it in. The only issue that’s stumping me (so far) is the projector.
The stupid hdmi cable they installed on this rubs and gets pushed down by the apron. This causes the projector to be aimed so high it won’t project onto half the targets. I have some adapter on order to see if I can fix it but was curious if anyone else had bumped into it and found a nice thin adapter that worked?
Edit: fixed - I used a razor to trim some of the hdmi cable plastic around the 90 degree turn where it plugs into the projector. That gave me just enough clearance that once the apron was install I could use my fingers and push the cable upward. That Seated the projector correctly in the mount
