(Topic ID: 300354)
Stern Godzilla Official Owners Club King Elwin
By beltking
2 years ago
  • 27,409 posts
  • 1,646 Pinsiders participating
  • Latest reply 2 hours ago by Nokoro
  • Topic is favorited by 1,029 Pinsiders
Topic poll
“What model did you order?”
  • PRO 285 votes
    20%
  • PREMIUM 897 votes
    63%
  • LIMITED EDITION!!! 243 votes
    17%
(1425 votes)
25 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 27,409 posts in this topic. You are on page 529 of 549.
#26401 3 months ago
Quoted from CapeCodPin:
Sorry, but A bottle of Rapid Tac is around $6 at the local True Value or Ace. If that's too rich for you, a couple of drops of Dawn dish detergent in a cup of water does the same thing. Either is far easier than lifting a playfield, if trying to do it alone, that is.
I'd gladly pay for Blitz, but no one has any for sale and it's no longer being made.
I don't personally find it difficult to remove the playfield, especially on a Spike 2 game. It's 3-4 connectors then it lifts out easily without any help. I used to have to disassemble all my machines to get them into my house so I got used to pulling the playfield on all my games.
#26402 3 months ago
Ok, me machine started to randomly freeze tonight... restarted twice during bootup before getting to game start, then would lock up after starting a ball, or sometimes when trying to use home team to log in... tried off and on, then reseated CPU cables and cycled the micro SD and memory cards in and out (power off of course). Same lock ups. During last play session earlier in the day, I had to really jostle the machine to free a ball stuck on the orbit flat spot. Machine was still playing then, but I quit because it drained my ball after doing it a second time- on the flat spot but now with "tilt off with coin door" and "coin door ball save" on, it relaunched my ball after I nudged it free just to hit the magnagrab at a glance and sent it SDTM, so I rage quit and shut the machine off. Come back this evening, it wont even play a single ball without locking up... any ideas?
#26403 3 months ago
Sometimes when I hit the left spinner, it will totally reject the shot and the ball will just go backwards and it will not spin. Is it just a part of the game that I have to deal with or is there a problem here? It’s been fine with the glass off with my hand, spinning it…..
It will just hit the spinner, then go back and not fully spin and work correctly. I think it’s just a part of the game, right?
Thank you for the help
Basically, just a brick spinner shot
#26404 3 months ago
Quoted from Bublehead:
Sounds like a bad SD card. Burn a fresh one and see if the problem goes away.
https://sternpinball.com/support/sd-cards/
#26405 3 months ago
Quoted from BrokenChair:
Sounds like your spinner needs to be adjusted. A pic may help in case it isn't sitting properly at rest.
#26406 3 months ago
Quoted from bigguybbr:
Ok, just to be sure, there are two memory cards on the CPU, a microSD and a SD... not sure which of these two you are referencing, the SD looks to hold game code, by it's sticker, but not sure what is on the micro SD card.
Can someone explain the difference between these two, and has the micro SD ever failed and needed replaced? Where do you get that image? Is the symptom of crashing the SD card failing or micro SD card?
#26407 3 months ago
Quoted from Mully911:
Hello All,
I know this has been gone over many many times, but I am still trying to fix/ adjust my shooter rod position to eliminate the rattle plunge when not using full stroke pull back. The Auto plunge also rattles at times....I read all the sticky posts on this but none of them seem to help, I made it worse I think. When adjusting the shooter rod position you can move it L&R and up and down. I adjust it so the rubber tip appears to be contacting the center of the ball but there is no way for me to really tell. Tip in on rod squarely.
Some short plunges attempting to hit the kill shot behind spinner result in a rattle job when the ball hits the back of the scoop protector...So frustrating
I also noticed cracked plastic under the bridge...what to do?
Please help!
Definitely get Freddy's shooter lane fix. I got it and have had nothing but smooth plunges since, and haven't changed anything else on my machine.
#26408 3 months ago
You should call/email Stern tech support. They need to know this happens and are well-equipped to help you resolve it.
It's probably a bad SD card, but the fact it boots up at all gives me pause. Talk to Stern. I've found them very responsive and quick to mail things if they need to.
#26409 3 months ago
Hello All,
Please help!
The Freddy’s shooter lane fix is great and recommended, but for me what really solved the problem (okay, in addition to the Freddy’s) was reinstalling my shooter. For whatever reason it just wasn’t properly lined up when I got my machine.
#26410 3 months ago
Quoted from tbaum:
cool thanks!
#26411 3 months ago
Quoted from barndawg:
Thanks!!
#26412 3 months ago
Quoted from Green-Machine:
Have you used a shooter lane fix of some sort? PM sent
No no yet, got one coming from Candy something...
#26413 3 months ago
I remember reading somewhere that when your down to your last ball on one of the multi-balls, if you press the action button you get 1 more ball? Is this true? When and how is it done>
#26414 3 months ago
if you have the Anguiris team up (add a ball) this would work by hitting the lockdown bar button. Does not have to be your last ball though.
#26415 3 months ago
Quoted from VinnyBlanc:
if you wait till last ball though, you can restart the whole multiball not just add 1 ball... give it a try!
#26416 3 months ago
Quoted from Baggerman:
That explains why my “add a ball” ends up being more than one in most cases. I tend to use Anguirus as a Hail Mary pass to save myself. I wonder if this is intended or a bug…
#26417 3 months ago
This was the post/diagram that helped me:
https://pinside.com/pinball/forum/topic/stern-godzilla-official-owners-club/page/269#post-7066823
There might be others up in the Key Posts at the top of this page.
#26418 3 months ago
Micro sd is for the insider connect I believe
#26419 3 months ago
Yes thanks I saw this and tried to align in the middle/center of the ball, but you cant really tell if it is in the center vertically and I made it worse...
#26420 3 months ago
Thanks guys, can you explain more? I am not a seasoned player.
#26421 3 months ago
There are a few seconds between when your second to last ball drains in the multi-ball, before you revert back to single ball play again, where you can press the Action button to at least add two more balls to the mode. Moreover, some multiballs have an in-mode function for adding another ball, like hitting the mecha-shield targets and then mecha-ramp in Godzilla Multiball, the right ramp that gets a superjackpot in Bridge i think also adds a ball, etc. Not sure about Tank, Saucer, the Tier 2, Monster Zero, Terror of Mecha, or Xilliens however for in-mode, but at the very least the action button will work there if you have Anguiris lit
#26422 3 months ago
You have to Earn an Ally first.
* Jet Fighters - Get 4
* Super Secret Skill Shot (under upper flipper - shoot scoop)
* Halfway through some Kajiu battles
* etc...
Then you have to shoot the scoop to gain your ally. Above your left flipper and in front of the scoop there are 3 lights on the playfield.
* Purple - Rodan - 2x playfield Scoring
* Yellow - Mothra - Left Outlane Save
* Green - Angurius - Add a Ball
You can use your right flipper to toggle these lights, while their blinking, before shooting the scoop. Once the scoop is hit, they will turn solid to indicate it is active.
If you have Angurius, you can then use your action button at any time during MB to "add a ball". If you time it right, when your 2nd to last ball is draining, you can press and actually get it to give you 2 balls for add a ball.
#26423 3 months ago
I would say most stern games have an add a ball feature so to do well you need to learn what it is for every multi ball of every game.
If used during a multi ball it will add a ball. It will also restart the multi ball if used when you drain down to single ball.
GZ has several ways to add a ball including Anguirus at the action button. But so does AC/DC if you’ve left one shot from a mode uncollected and have a VIP pass. Great info to learn for every game
#26424 3 months ago
Quoted from KJL:
Just as a clarification, if you press it right as the last ball drains. It technically doesn't restart the multiball, it sends out the extra ball and starts the ball save, which saves the last ball. So if several go down at the same time, you can save all of them by hitting the "add a ball button".
#26425 3 months ago
Quoted from Brombomb:
And just a tiny bit after
I love that moment when things are settling and I am smacking the right flipper to get what I want.
#26426 3 months ago
So on my premium the bridge plastics hit each other when the bridge is moving. The front was easy enough to adjust but how do I get at the back? Two of the screws are completely covered by the metal bracket, the other two are visible but no real way to actually get a tool on them. The only way I can see to do it is remove the entire assembly, not really looking forward to that.
#26427 3 months ago
Quoted from Syco54645:
If you use a real long screw driver you can get to three of them. The fourth you gotta lift the bridge up to get at it barely, or loosen the mechanism.
You’ll need to lift the back of the playfield useing plastic clamps or playfield jacks.
#26428 3 months ago
Quoted from junkyard:
I do not see how that would be possible, the screws near the pivot point are completely covered by the metal bracket. I will give it another look later and see if I can get at them with a longer screw driver.
#26429 3 months ago
I could be remembering it wrong. I changed mine out for art of pinball ones and removed the bridge to do it. Really isn’t that hard to remove them.
14
#26430 3 months ago
I replaced the four bridge plastic pieces with new stainless steel pieces (available from Chrome Candy). Accessing that PIA screw so you can lock it down will take a little work, but here's what you gotta do:
1. You will have to raise the playfield in such a fashion that you have access to the back of the bridge assembly. Pull the playfield out so that the rubber on the service rails rests on the lock bar receiver. I then used a c-clamp, attaching it to one of the support rails to ensure the playfield would not slide off. Raise the back of the playfield out of the machine and use support blocks or a broomstick / dowel to rest the playfield out of the cabinet. See image 1.
2. You will now need to remove four 6-32 screws. The first of these is on the back side of the bridge. To access it the bridge must be lifted upwards. In the pic below, a small towel is being used to hold it in the up position which moves the plastic arm away from the screw. To remove this screw, it is necessary to use a 5/16” wrench to keep the piece on the other side from rotating. See image 2.
3. See image 3. Remove these 3 screws from the front of the bridge. It is not necessary to remove the C-clip.
4. You should now be able to lift and rotate the end of the bridge assembly so that the PIA screw can be accessed. See image 4.
Hope this helps.
Pinside_forum_7408594_0 (resized).jpgPinside_forum_7408594_0 (resized).jpgPinside_forum_7408594_1 (resized).jpgPinside_forum_7408594_1 (resized).jpgPinside_forum_7408594_2 (resized).jpgPinside_forum_7408594_2 (resized).jpgPinside_forum_7408594_3 (resized).jpgPinside_forum_7408594_3 (resized).jpg
#26431 3 months ago
Quoted from John_C:
1. You will have to raise the playfield in such a fashion that you have access to the back of the bridge assembly. Pull the playfield out so that the rubber on the service rails rests on the lock bar receiver. I then used a couple of strong zip-ties to tie the rails to the lock bar receiver so it would not slide. Raise the back of the playfield out of the machine and use a broomstick / dowel to rest the playfield out of the cabinet. See image 1.
Hope this helps.[quoted image][quoted image][quoted image][quoted image]
Thank you for this excellent visual and textual explanation.
#26432 3 months ago
Ok, to update my recently built premium problems... there are some things they are aware of...
If your recently built GZ premium has a building entrance opto that has failed for any reason, they think they might know why and will adress it if you call support. They have a couple of recommendations that depend on your symptoms and how they failed. Call and put in a ticket.
If you are getting random lockups, turn off the power, remove the micro SD card from the CPU board, (NOT the SD card, which is physically bigger and holds the game code image) and restore power. Does it boot and play now? If so, replace the micro SD card with a blank, new micro SD memory card, the same size as the one you removed, and at least one with a minimum Class 10 speed rating. No need to format it, it will be detected and formated when you turn on the machine. The micro SD card is scratchpad storage for Insider Connect communication, it is designed as replaceable scratchpad memory that gets written to and read from during IC communications and instead of using expensive ram, or the game code SD card, they opted for cheap uSD memory so if read/write cycles wear it out after a while, operators can restore IC communications by simply swapping in a new memory card. Now if they would have just used a better supplier of micro SD cards...
And put in a call and a ticket... they will not probably spend that extra $0.05 for a better uSD card until they find more than 15% - 20% failure rate, so lets tell them were to stick the latest batch of uSD's, shall we?
#26433 3 months ago
Quoted from John_C:
Thank you so much! This is a great explaination and will help a lot of others as well. I will be embarking on this soon.
#26434 3 months ago
I originally went with the “Abe Flips” plastic shooter lane fix for Godzilla. It did provide some improvement on reducing rattle during plunges. However, this full length, stainless steel replacement is even better. I got it from Chrome Candy. Highly recommend it…
I may not even need to install the playfield alignment brackets that I ordered now. Mine shipped with neither installed.
#26435 3 months ago
I intended to release this shortly after my other Godzilla DMCS mods but then got distracted developing the Foo Fighters DMCS Save Post. I finally got back to this and am releasing it now.
This is the Godzilla DMCS Backbox Light Kit with animated and interactive effects. It lets you choose the attract and gameplay modes independently. In this demo the attract mode is set to "Animated Attract Sequence" and the game mode is set to "Dim with Interactive Effects". There are other modes to choose from such as "Dim Static" or "Bright Static". There are at least 9 in game effects triggered by play events, including rising flames, and streaming heatray (which I forgot to activate but it's similar to the one shown in the attract mode at the start).
More details in the GZ DMCS mods thread if you want to get in on the January special:
https://pinside.com/pinball/forum/topic/godzilla-dmcs-mods-xilien-saucer-heatray-diverter-burning-building#post-7297735
#26436 3 months ago
Thanks for mentioning this, ‘cuz the Abe Flips mod didn’t really help very much. Looks verrrry similar to the one you installed, though?
#26437 3 months ago
Quoted from bwalter:
The one I was holding (pictured) was the old one. The new one, installed, you can see behind it on the machine.
#26438 3 months ago
Quoted from HighVoltage:
I assume this is for the Pro only?
#26439 3 months ago
Quoted from math08:
I can adapt it to the premium or LE, I just need at least 5 orders, or if someone wants to send me their translite I'll do it and send it back with the backboard. The heatray and flaming fires are the main effects and will translate over easily, and I'll substitute a few other things. The pro artwork worked out particularly nice since it has so much from the game: pulsating spikes, tesla tower, mecha godzilla.
#26440 3 months ago
Just replaced my first Power Distribution Board (on Godzilla). I was having an issue where the coin door interlock was not working (cutting 48v power). I obviously started with swapping the interlock switch first and that didn’t work. Did some googling and I saw people in the Jurassic Park group on pinside has the same issue and swapping the Power distribution board worked. I gave it a shot and voila!
#26441 3 months ago
How would I know if the building entrance opto is not working
#26442 3 months ago
Quoted from Bunzy:
Here are 3 different ways to try:
- shoot a ball into the building and the shot doesn’t register, or
- go into active switch test and the opto is registering when it shouldn’t be, or
- go into switch test and roll a ball past the opto and switch test doesn’t register it.
#26443 3 months ago
Where do you buy a power destroy board? VinnyBlanc . Is this a stern part?
#26444 3 months ago
Quoted from Tophervette:
From Stern: https://shop.sternpinball.com/products/spike-2-power-distribution-board
Other pinball parts retailers sell them too.
#26445 3 months ago
I have a dumb question. After beating the first monster in Tokyo, how do you light the white ramp lights so you can start the next Kaiju battle? I had GZ multiball ready (2 balls on roof) but I didn’t want to start it until I started a battle.
#26446 3 months ago
Quoted from JP76:
Hit the scoop and change cities.
#26447 3 months ago
I got it from Pinball Life for $75. Yes it’s a standard Spike 2 component and found in the backbox next to the power supply
#26448 3 months ago
Quoted from bush3262:
You need to light kaiju battle at the scoop first, but you need to shoot 2 ramps when lit in order to do that. My question is how to light ramps?
#26449 3 months ago
Quoted from JP76:
The ramps don’t need to be lit (or qualified) to count toward kaiju battles. The white arrows on the ramps are just with respect to destroying the building.
#26450 3 months ago
Wife and I just keep getting screwed over by the putlanes. What’s the best way in settings to overcome the ball constantly going out on us? New to pinball
$ 73.99
Cento Creations
Daddio's 3D Printed Mods
$ 185.00
Sparky Pinball
$ 115.00
Raiden Mods
$ 210.00
€ 168.00
Lighting - Backbox
Watssapen shop
$ 28.50
Pinball Pro
Slipstream Mod Shop
8,700 (OBO)
Monument, CO
$ 55.00
arcade-cabinets.com
€ 40.00
Pino Pinball Mods Shop
$ 120.00
Dijohn
$ 80.00
Reflex Mods
JuanSolo's modshop
Trade
Machine - For Trade
Blacklick, OH
6,999
Wood Dale, IL
€ 50.00
€ 168.00
Lighting - Backbox
Watssapen shop
8,400
Land O' Lakes, FL
$ 100.00
Chrome Candy
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/stern-godzilla-official-owners-club/page/529 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
