Quoted from sfspanky:Standard LEDs. You will see improvements with non-ghosting in the inserts with the OCD board, but you’ll see the full advantage with standard LEDs.
There are (2) "different" OCD systems, BOTH which help the STTNG Pin. GI-OCD is for the General Illumination system, and removes the flickering led bulds (standard or non-ghost, it doesn't matter) will have. In addition, it returns the unique feature in the STTNG machine, SHIELD STRENGTH. When the call out "Shields are at 20 percent" The shields on the playfield will be dimmer (not flickering), just on but dimmer. In the test mode, under GI lighting test, everything level of lighting will be available. Non OCD systems with leds will flicker/stobe until level 7 is reached, then they will be on solid.
LED-OCD is the system for ALL INSERTS, allowing them "ramp on and ramp off" smoother than the instant ON / OFF. Returning the look of the machine to original, however with the benefit of leds.
