Quoted from BOBCADE:Very nice. I haven’t gotten to a list of things on mine, and lighting these up is on that. What led strips did you use and where did you patch power in?
Here are details on how I added sideblade illumination to my Ripley Version.
Here's what I used for the LED strips: https://www.amazon.com/dp/B0C149NXWB
The LED strips are 12 volt and can be cut to any length. You will want two LED strips cut to 42 inches in length.
Hopefully your soldering skills are up to par. You will want to attach wires to the LED strips before you install them. I also made use of molex connectors so it would be easy to plug them in once installed.
In order to install the LED strips in the cabinet, you have to remove the sideblades. And the only way to remove the sideblades is to lift the playfield out of the cabinet. What I did was put a couple of c-clamps on the lower end of the support rails, lifted the back of the playfield out of the cabinet, and then rested it on a board laid across the top of the cabinet. The c-clamps act as stops so that the playfield doesn't slide off the cabinet.
With the sideblades removed, you'll see that there is a channel that has been milled into the cabinet side running along the bottom of the sideblade cutouts. This channel is approximately 7mm wide by about 3mm deep. The LED strips are 5mm wide and have double-sided tape on them so installing them is easy-peasy; just remove the paper from the double-side tape and lay / stick the LED strip in the channel.
Also, I chose not to power these from the machine's cabinet controller. I've read too many stories of how temperamental the electronics in this machine can be. Awhile back, I installed a separate power supply to power all of my mods and I chose to power these LED strips with that second power supply as well.
Hopefully this helps others with this project.
- John
Table_Support_01 (resized).jpgTable_Support_02 (resized).jpgTable_Support_03 (resized).jpgTable_Support_04 (resized).jpgCabinet_LED_Strip_02 (resized).jpgCabinet_LED_Strip_03 (resized).jpgCabinet_LED_Strip_01 (resized).jpg20240426_172819[1] (resized).jpg
