Quoted from Mageek:I have mine at 6.7°
Here are some things to look at
1) Be sure to adjust the spinners so that they are vertical at rest and spin easily or they will brick
2) Ensure the right orbit takes the ball to the right flipper, if not you may need to adjust the ball guide and make sure the ball is not hitting target 5 and deflecting coming out of the orbit
3) Scoop should smoothly send the ball to the left flipper, lower the coil power or follow PB adjustment procedure if not.
4) Try different coil setting for upper right flipper to help dial in your hypersleep shot
individual flipper angles are a big thing here too. each has its own sweet spot!! For my lowers i have them parallel to the lane guides. Upper right has a "droop" to slightly behind post. Upper left is slight droop from lane guide.
