Quoted from Mrsiyufy:In March 2021 I bought a NIB Wonka LE that had a manufacturing date of 11/2019. So more than enough time to cure, checked and snugged everything right out of the box I even added washers below the sling posts and 30 Plays in pooling started. It’s just the luck of the draw.
I'm not sure it is luck of the draw.
Notwithstanding my Dragonfist play field Mirco seems to have decided to keep, I have built 2 of his Quicksilver play fields and one Nine Ball play field. I had pooling problems with one of the play fields and the other two are suspect but what I did was to use bonded Neoprene washers under each an every post. That solved any pooling problems.
These are nice because after you tighten the post down, the washer keeps it up and away from the play field and you can hook a fingernail under the post. I recommend them for any build on any play field.
https://www.amazon.com/Neoprene-Bonded-Sealing-Washers-Stainless/dp/B07WX7HNGD/ref=sr_1_3
Here is the problem I ran into with my first QS play field. I had a slingshot post split sometime during the night. And the post acted like a shovel and dug out a chunk of paint. Mirco tried to blame me by saying I over-torqued the post. I persisted and he did send me a replacement play field and I kept the this one and made the repair.
Here is some post distortion at a couple of other post locations on this play field. Using the neoprene washers stopped this problem.
And this is a post area on a pin that I restored and clear coated 5 years ago. There is no pooling, etc. I think Mirco is using some substandard clear on his pins, but he knows all and will not listen.
This post area is why I will always be using the rubber washers going forward.
