Sorry if this is off topic but I think the people in this thread are the type who would appreciate this the most since we understand precision manufacturing/machining.
For the last year or so there has been an effort to do high quality metrological scans of several granite vases from dynastic Egypt. The results have been completely mind blowing.
Several of the scans can be found here including STLs if you want to 3d print them.
https://unchartedx.com/site/vase-scan-resources/
Someone also did a mathematical analysis of one of the scans and showed that the relative accuracy of the surfaces was within 75 thousandths of a millimeter when compared to a purely mathematical model of the vase. This implies that these had to be designed with a computer and machined with precision manufacturing tools. They are made of granite too which is a very hard to work with substance due to the hardness and the lack of homogeneity.
"This led us to attempting something, that really should not have been possible, when dealing with a supposedly ancient artefact, made from granite, of all things: We decided to experimentally build a CAD model that would exclusively use mathematical concepts to dimension and place the features of the object, and use no tuning or arbitrary positional adjustments. All features should be placed and dimensioned by interrelation to each other.
We also limited the initial margin-of-error tolerance of the model to 75 μm
, in terms of how well it should map to the features of the actual object. This margin-of-error tolerance was, amongst other criteria, used to discern whether an attempted modelling of a particular feature should be considered for inclusion in the model, or rejected.
I find it timely to stress how completely ludicrous this actually is. We are dealing with a stone vessel of supposed ancient origin, and are now proposing, that a purely mathematical CAD model, should somehow map to the actual object within a tolerance of less than 75 thousands of a millimeter.
Here, at least 15 levels of interrelation exists, and they are all precisely in harmony, down to microscopic scales.
This object was meticulously and carefully designed by a human being, with incredible levels of skill, insight and artistry. Of that, there can currently be no doubt."
That analysis can be found here.
https://unsigned.io/articles/2023_03_17_Abstractions_Set_In_Granite.html
The handles are another peculiarity. If these were made on a spinning lathe they'd have to somehow create the handles after and to keep the precision to the level we see would make that incredibly difficult. It's as if they were using a multi-axis lathe.
The only real way to refute this analysis is to say they are not genuine artifacts, but modern fakes. Even if they were modern fakes to make them in granite with such a level of precision would make the cost far outweigh any price you could fetch for them. It's really mind blowing how precise these things are!
EDITed to add the video showing their scanning process and some of the crazy tolerances these vases achieved
