Quoted from cpr9999:Curious what experienced 3d printer experts can help me understand….what is best home 3d printer??? ...
There's no one best answer. To get your feet wet and to understand the principles of 3D printing, get an Ender 3. It costs less, replacement parts are dirt cheap and widely available, and there is tons of advice on how to use it. It will do the job, but it is made to the price point and there is lots of room for improvement. Read toyotaboy's reply above for examples of improvements.
I went with the Prusa because it already comes with all the improvements that I would have made to an Ender 3. It is $800 delivered (if you build it yourself) or about $1100 plus import duties for the fully assembled one. It isn't the most convenient choice. There are no consumer distributors in the USA, except for some replacement parts. At the moment, it takes a month to get, give or take.
Went straight from almost zero experience to a >97% print success rate. (It would be >99% if I had chosen to buy the smooth PEI sheet, but I wanted the textured one. They now sell the printer with both, if you want them.) It needed only 1 adjustment (the Z-height), and I did that twice because, well, zero experience. All other adjustments are automatic.
toyotaboy is correct about the hot end. It's surrounded by part-cooling vents and even just seeing it is awkward. People accidentally break wires trying to remove and replace the nozzle. If it needs major maintenance the hot end has to be broken down piece by piece. So far I haven't needed to do that. In almost two years I've lubricated the bearings, replaced one nozzle, tightened the extruder screw (my fault for loosening it too much for flexible TPU material), cleared one filament jam (through the door on the side of the extruder) and repaired the filament sensor (factory production flaw; I took a razor blade and trimmed off a millimeter or so from one plastic piece and put it back). Very little hassle.
