This MkII kit is an upgrade of the first kit that's been under testing, I recommend reading about the first kit if you're not familiar with it:
https://pinside.com/pinball/forum/topic/modified-doctor-who-mpf-elevator-2nd-mod
This thread is the Interest / Waiting List!
It's been more than three years since I started this so please have patient with production, I'll make these kits when I find the time so waiting time may vary and be long!
I'll get in contact when it's your turn and I don't want to take pre orders or money in advance, it's fine to refrain from buying this kit or if you wish to make some changes when the turn comes to you, PayPal payment in sek before shipping after the kit is finished, with currency rate at the time.
A 5% donation will be generated to Pinside for each sale.
This kit replaces the inner bracket, all five metal rollers, their washers and the upper brace.
In order to install this kit you need the outer bracket with optos, a fully functional motor and gearbox with its bracket, these parts should be intact without any major damage.
Three holes in the bottom of the Outer Bracket has to be drilled to install the Bottom Reinforcement.
If you choose to use the Original Cam, a 5mm hole has to be drilled through the small shaft and a piece of one opto slot has to be cut away to achieve correct height in the middle lift position.
Updates made from the first kit:
* Thicker shafts which can be used with three different types of bearings on the Upper Linear Shaft Bearing Units:
#1 IGUS Type Bearing of Solid Polymer RJMP-01-06, these bearings was what I initially planned to use but they were not available for the thinner shafts on the MkI Kit, these are what I recommend!
#2 Linear Ball Bearing LM6UU, used on the MkI Kit, still working fine in the MkI Beta kits.
#3 Self Lubricating Graphite Brass Bearings JDB LM6UU LM6, not tested and more expensive, these will be sold separately as an option but I don't consider them to be suitable for this application.
* Some parts is now being FDM Printed in PC and PETG.
* New design for the Upper Linear Shaft Bearing Unit for the Larger Bearings.
* New design for the Lower Linear Shaft Attachment for the Thicker Shafts with damping and more material for the shaft attachments.
* Bracket Chims of PETG for leveling the Mini Playfield against the Playfield included.
* Modified Cam available as an Option, the Original Cam can still be used but has to be modified as in the first kit.
* Brass Connecting Hex Rod instead of Aluminium.
* Some measurement changes.
The parts thats now being replaced by 3D printed PC and PETG is in bottom and on the sides of the bracket since these parts mainly acts as guiding and are not under much force or pressure:
# The Upper Linear Shaft Bearing Unit PC.
# The Outer Linear Rail Attachment PETG, Aluminium available as an option.
# The Outer Bracket Bottom Reinforcement PETG, Aluminium available as an option.
I've researched and tested different types of plastics and brands for these parts and found what i required in desired strength and toughness, these parts are all 100% Infill PETG and PC (Makrolon/Lexan).
Available colors for the Outer Linear Rail Attachment and the Bottom Reinforcement made of PETG:
# Jet Black RAL 9005
# Sapphire Blue RAL 5003
Other Colors on demand.
Inner Linear Shaft parts of PC is made in Black only.
Parts attached to the Mini Playfield is still made from aluminium, the kit have not yet been confirmed to fit with the cpr repro mini playfield.
The kit has been installed and tested with the 3D printable opto cover made by jmathews https://www.thingiverse.com/thing:2387162
Prices in Sek, updated 201122, 2A is now standard for the Basic Kit, option 2 is no longer available.
Basic Kit 2000 sek + 500 sek (2A Option) + Trackable Shipping, Postnord prices 200304; USA, Canada, UK & Australia +152 sek, Europe +190 sek, Sweden +63 sek.
Overview of Lifter Kit Parts (updated 200106)
Basic Kit:
1. Pre-assembled and Loctited connecting rod and center MPF attachment.
2̶.̶ ̶P̶r̶e̶-̶a̶s̶s̶e̶m̶b̶l̶e̶d̶ ̶l̶i̶n̶e̶a̶r̶ ̶r̶a̶i̶l̶ ̶u̶n̶i̶t̶s̶ ̶f̶o̶r̶ ̶L̶e̶f̶t̶ ̶a̶n̶d̶ ̶R̶i̶g̶h̶t̶ ̶s̶i̶d̶e̶,̶ ̶M̶G̶N̶1̶2̶C̶-̶1̶5̶0̶ ̶L̶i̶n̶e̶a̶r̶ ̶G̶u̶i̶d̶e̶ ̶R̶a̶i̶l̶ ̶w̶i̶t̶h̶ ̶R̶J̶M̶P̶-̶0̶1̶-̶0̶6̶ ̶B̶e̶a̶r̶i̶n̶g̶s̶, No longer available.
2A. Pre-assembled linear rail units for Left and Right side, MGN12C-150 Linear Guide Rail with RJMP-01-06 Bearings. Lower Shaft Attachment of Aluminum, add 500 sek.
3. Outer Linear Rail Attachment of PETG in Jet Black or Sapphire Blue.
4. Bottom Bracket Reinforcement of PETG in Jet Black or Sapphire Blue.
5. Brace with fixed c-c (center to center) distance.
6. Drill Templates for Outer Bracket and Gearbox Bracket (colors vary).
Options:
3A. Outer Linear Rail Attachment of Aluminum with logo and unique TAG, available as option, add 500sek.
4A. Bottom Bracket Reinforcement of Aluminum with logo, available as option, add 200sek.
Thanks to dahlman at Degerforce Pinball for development of the Modified Cam that Im now able to offer for sale as well.
This Cam has correct height for the elevator in both middle positions.
Note that this Cam has a Round hole and is missing the D arbor hole, it has two sturdy set screws instead and is made of thicker sheet metal, limited at this point to one/kit.
1pcs Modified Cam, One Offer/Kit, 600 sek, Raw Sand Blasted Steel if you wish to paint it yourself + extra shipping cost, Postnord prices 200304; USA, Canada, UK & Australia +64 sek, Europe +80 sek, Sweden +32 sek.
Add +100 sek extra powder coated version, Fine textured matte, Black or Sapphire Blue.
The new improved motor controller board by pellew can be shipped together with the kit at no extra shipping cost.
https://pinside.com/pinball/forum/topic/improved-motor-driver-a-15680-for-doctor-who
There are No Guarantees with this kit, All work, installation or operation with the elevator is at your own risk and responsibility!
I'll do my best to support you though.
This is mainly functional parts, visible imperfections will occur on some surfaces!
This kit will not solve any problems if you're using a bad gearbox with Stripped Gears or a Wobbling Main Shaft.
Any additional extra costs like customs, taxes or PayPal fees is not included, shipping prices may vary.
Put your interest in this thread If you're fine with these conditions.
Add which options and color you want, not necessary but it's helpful when I'm buying more material.
Claim your TAG/Three or Two Digit/Letter/Symbol if you're looking to buy the Aluminium Outer Linear Rail Attachment Option.
