Quoted from blowback1976:Just picked up a Freddy, that has some odd issues. One is all flashers do not work, previous owner had mix of LEDs and incandescent, not sure if that would be a cause. Also the right flippers only work sometimes during games, but both coil and flipper switch register fine in test. Anyone have any insight, while I wait for the manual to arrive.
Lamps on System 3 games are polarized. If an LED doesn’t work, it’s often because the lugs were soldered in backwards. So check the suspect sockets with an incandescent. If it works, either the LED is bad, or you need to reverse the lugs (de-solder, flip and resolder).
Flippers are operated mechanically. No CPU control like fliptronics. The switch test will only tell the CPU of a switch closure for things like lane change and putting in initials. Diagnose non-working flippers as you would any other game: check for loose wires at lugs, and check the flipper relay contacts in the bottom of the cabinet.
