(Topic ID: 239307)
Black Knight - Sword of Rage Club - Honourable Knights Only
By NeilMcRae
5 years ago
  • 5,884 posts
  • 551 Pinsiders participating
  • Latest reply 9 hours ago by gunstarhero
  • Topic is favorited by 218 Pinsiders
Topic poll
“Black Knight - Sword of Rage Club - Honourable Knights Only”
  • Pro 83 votes
    36%
  • Premium 61 votes
    27%
  • LE 86 votes
    37%
(230 votes)
This poll has been closed.
5 key posts have been marked in this topic (Show topic index)
There are 5,884 posts in this topic. You are on page 103 of 118.
#5101 1 year ago
Quoted from johnnyutah:
That does look way better.
Another cool thing about the BKSOR Pre at Ground Kontrol is that they placed the magna save button next to the right flipper button. That’s seems like a must do mod as well.
That’s cool. Do you have any info on that magna save mod?
#5102 1 year ago
Quoted from madamyates:
I guess I should have been more clear. I don’t have the CN9 connector cable.
You can make your own connector pretty easily. What is it for?
#5103 1 year ago
I have no info other than the machine at Ground Kontrol has the magna save button next to the right flipper button on side of cab just like the OG Black Knight next to it and how my RM had.
I might be able to go back today if they open. They have been closed because of the snow storm. If they do open I’ll take pics of button mod and report back. Here are the machines they have though:
C354DC5A-0B9D-42B7-A466-2D7272A101A2 (resized).jpegC354DC5A-0B9D-42B7-A466-2D7272A101A2 (resized).jpeg
#5104 1 year ago
I have these connectors if you need a few. J
D927B430-BC8E-463D-A5A8-5EA0D11D3D7F (resized).jpegD927B430-BC8E-463D-A5A8-5EA0D11D3D7F (resized).jpeg
#5105 1 year ago
Quoted from Jrotten:
44DA1C1B-94E0-4FE9-A6D2-E1E8475D4A00 (resized).jpeg44DA1C1B-94E0-4FE9-A6D2-E1E8475D4A00 (resized).jpeg
#5106 1 year ago
So the BKSoR Premium hasx two problems my Pro had not and I'd like to ask for help.
Main thing is, the center target very quickly leans to the side and then stops registering. I remember there was some kind of hardware fix/ clamp thingy for that but I can't find it. If someone would put me in the right direction I'd appreciate that.
The other problem ist the right flipper having problem making the ramp, that's self explanatory... have to rebuild the flipper these days.
#5107 1 year ago
I do not seem to have the CN9 DBA connector inside my LE. Any idea why it would be missing? I bought this NIB and all of my other Sterns have it.
Stern did not start adding a connector to the CN9 cabinet node connection until Avengers: Infinity Quest. I guess before then, it was up to folks to find or make their own connector to plug in there.
Out of curiosity, you are looking to use it for a +12vdc bill validator? I know that is what it is intended for, but as someone that has sold light kits that has used that CN9 connection for power since SPIKE 1 was released.....I have never heard of anyone needing it or anyone using a +12vdc bill acceptor for that matter. All of the ops that I have sold light kits to have used +110vac bill validators (which obviously, do not use that +12vdc CN9 connection).
#5108 1 year ago
Having an issue where in mode activation, the shield either won't come up or does come up but then randomly goes down during play and blocks the scoop, meaning mode activation impossible. It always-always goes up and stays up if you drain, at the start of the next ball. Any clues on where to begin investigation? Tried searching forum but results were all over the place picking up on random keywords. Appreciate it!
#5109 1 year ago
Quoted from chickenscratch:
The shield should only be up when mystery or mode or lock is lit.
If it is not going up at those times, then perhaps something going on with the opto for it? I have not heard of this issue.
#5110 1 year ago
Quoted from koji:
Ya it does 95% of the time go up initially but then just kinda falls down, like the shield is too heavy
5EDF36DE-EE26-4213-8949-E34B6163B5CF (resized).jpeg5EDF36DE-EE26-4213-8949-E34B6163B5CF (resized).jpeg
#5111 1 year ago
Ya it does 95% of the time go up initially but then just kinda falls down, like the shield is too heavy [quoted image]
https://pinside.com/pinball/forum/topic/black-knight-swords-of-rage-club-honourable-knights-only/page/102#post-7417160
Looks like there is an allen key lock on the shaft to move it up. That would be my guess to tighten this?
#5112 1 year ago
Quoted from koji:
Perfect, will check that out - thank you!
#5113 1 year ago
Doesn’t appear to be a mechanical problem with set screws or anything; everything tight in shield assembly. I think it may be a weak coil that drops the shield as shield up is coil activation. I’ll test resistance with a multimeter to see if anything funny. Opinions on if it could make sense the coil strong enough to open/close strongly but weak enough to not hold while activated?
#5114 1 year ago
I’ve not been into a SPIKE system but if it was a SAM game I’d be checking the power transistor that drives that coil
#5115 1 year ago
Installed my new sword ramp mod. This thing looks like it came from the Stern Factory. It’s very well made/designed. Definite improvement to game play.
827A69C0-C1C2-4E28-8000-5B8A37084EFB (resized).jpeg827A69C0-C1C2-4E28-8000-5B8A37084EFB (resized).jpegC49D9E6F-B903-49CE-8446-BEAB4C984F7E (resized).jpegC49D9E6F-B903-49CE-8446-BEAB4C984F7E (resized).jpegCA0EF8E9-700D-49C0-8646-46266785DD3E (resized).jpegCA0EF8E9-700D-49C0-8646-46266785DD3E (resized).jpeg
#5116 1 year ago
Quoted from NinJaBooT:
I'm more intrigued by the spinal columns hanging along side the machine...more specifically, where they came from.
#5117 1 year ago
Quoted from Photopin:
Those are from the never to be released Predator pin. Or if they aren't, they were inspired by them.
#5118 1 year ago
Quoted from OutlawTorn304:
One needs to take out a transistor from the PCB to test, correct? I don’t think you can test them connected and in-line. I’m not sure a DMM would work either, if I remember correctly from my engineering days long ago; oscilloscope?
#5119 1 year ago
#5120 1 year ago
I don’t bother testing them. They are cheap and easy enough to change. If suspect one is weak I just swap it.
#5121 1 year ago
Now I’m second guessing myself; should the flail be moving 1 step at a time about every 3-5 seconds during attract mode? I hear the stepper motor moving a click and can see the flail rotate the tiniest bit.
If not supposed to occur may be a lead to why my flail is randomly stopping during spinning (during gameplay and self test). Thoughts on what to check for that? Could be related to shield issue.
Thinking this might be a loose connection somewhere as shield was fixed for a few hours today until I had to move it to try and fix flail issue, which occurred during addressing shield issue, and now shield issue back after moving/futzing pin again.
Video: https://www.dropbox.com/s/hupmaltedh0wxls/Video%20Mar%2005%202023%2C%204%2009%2010%20PM.mov?dl=0
#5122 1 year ago
I got a pro BKSOR recently. This game is so damn good. I can’t believe I didn’t get one of these sooner. My wife and kids even love it which was surprising to me (minus the two pieces of painters tape we needed to cover the skeleton eyes on the front haha)
AEDCA6CA-8528-4FB0-B98B-3E433E65D840 (resized).jpegAEDCA6CA-8528-4FB0-B98B-3E433E65D840 (resized).jpeg
#5123 1 year ago
Quoted from TheBeefSupreme:
Congrats! I LOVE this pin. Between all the pins I own including GZ, IM, JP, etc. it’s still got a special place in my heart as the true favorite. Many of my kids go to as well. FUN!
#5124 1 year ago
I just noticed the flail motor steps at the same time all GI goes out and flashers come on for a brief second so likely some short/grounding issues. I just reseated every connector under the playfield and the issue went away, for now.
#5125 1 year ago
Welcome to the club Pro! What is the color your powdered coating? Gold, bronze or silver vein?
#5126 1 year ago
Most likely there was a miscommunication between the nodes due to a loose connection at the Ethernet cable.
#5127 1 year ago
Quoted from Shogun00:
I noticed an intermittent hissing sound coming from node board 9 that was in sync with issue (opposing sync) and through process of elimination disconnecting CN3 stops hissing and the flail issue.
Looks like that goes to node board 9a so need to eliminate variables there now and find source of issue. While I had CN3 disconnected, it takes out most all of the upper playfield lights, but I noticed it went dark-dark up there when I switching WAR lane lights; found out that rapidly hitting right flipper button is causing it to all go dark back/up there, so may need to trace that all out too.
Making progress!
#5128 1 year ago
Making progress!
Eh… ended up being a red herring. Found out the hissing can take a couple minutes to “build up” so ended up following potential leads a little too quickly. Eventually every lead has proven itself false even when “correct” 95% of the time. Only thing that works is disconnecting power to node 9 but want to isolate more before I do any rip and replace on any other potential red herring.
Video of the hiss / sizzling sound: https://www.dropbox.com/s/ye2rpaagp4kmaba/Video%20Mar%2005%202023%2C%209%2007%2016%20PM.mov?dl=0
Symptoms once the upper playfield lights start kicking out and flashers coming on briefly: https://www.dropbox.com/s/c32rle20ksc0cf8/Video%20Mar%2005%202023%2C%209%2027%2059%20PM.mov?dl=0
Think it’s either a failing transistor or power cap but would like to figure out which. Open for ideas.
#5129 1 year ago
Quoted from gprotein:
Thanks! It’s a silver vein. The previous owner did it but I like it a lot.
#5130 1 year ago
Eh… ended up being a red herring. Found out the hissing can take a couple minutes to “build up” so ended up following potential leads a little too quickly. Eventually every lead has proven itself false even when “correct” 95% of the time. Only thing that works is disconnecting power to node 9 but want to isolate more before I do any rip and replace on any other potential red herring. Think it’s either a failing transistor or power cap but would like to figure out which. Open for ideas.
#5131 1 year ago
Just want to say hello as being a new owner of BKSOR pro. I love this game!!! As being just Knighted I don't want to stop! LOL. I would like to replace the speakes as they don't seem that good. What would be some good ones short of $$ pinwoofer.
#5132 1 year ago
What is the fix for this? If I shake the game, it will come loose.
07DAF870-018D-4F3A-97AF-E184121C70B1 (resized).jpeg07DAF870-018D-4F3A-97AF-E184121C70B1 (resized).jpeg1D59464D-C3FE-4D61-B000-5A0832760310 (resized).jpeg1D59464D-C3FE-4D61-B000-5A0832760310 (resized).jpeg
#5133 1 year ago
Quoted from blainedoe:
https://www.pinballlife.com/stern-le-speaker-set-5-14-4-ohm.html
I think these work great. I upgrade all my premiums to match the LE.
You’ll need more than the speakers. New speaker grills, gaskets, plastic stands, colored plastic. Very easy upgrade.
#5134 1 year ago
I found a NIB Topper but have no idea what they are going for now- whats the market price on these right now? It's BNIB.
black-knight-sword-of-rage-topper-stern-pinball-806352_663x (resized).jpgblack-knight-sword-of-rage-topper-stern-pinball-806352_663x (resized).jpg
#5135 1 year ago
Quoted from Pinball-Wiz:
Where did you find a NIB topper??
#5136 1 year ago
How do I stop this from happening?
57BAB473-CD83-4D0B-99D5-5981B7641FFD (resized).jpeg57BAB473-CD83-4D0B-99D5-5981B7641FFD (resized).jpeg9894E0F8-5D5A-402F-B104-2963643B5BF8 (resized).jpeg9894E0F8-5D5A-402F-B104-2963643B5BF8 (resized).jpeg
#5137 1 year ago
Quoted from Trekkie1978:
Complete luck of the draw.
#5138 1 year ago
Used ones are bringing $2500
#5139 1 year ago
I would buy that topper from you if the price isnt insane. Pm me
#5140 1 year ago
I have new / never populated BKSOR Pro playfield - Stern sent it to me and I sold the machine before swapping it.
I am going to TPF and can deliver it there. Or could ship - still have the original shipping box.
$650
IMG_7890 (resized).jpgIMG_7890 (resized).jpgIMG_7891 (resized).jpgIMG_7891 (resized).jpgIMG_7892 (resized).jpgIMG_7892 (resized).jpgIMG_7893 (resized).jpgIMG_7893 (resized).jpgIMG_7894 (resized).jpgIMG_7894 (resized).jpgIMG_7895 (resized).jpgIMG_7895 (resized).jpgIMG_7896 (resized).jpgIMG_7896 (resized).jpg
#5141 1 year ago
If I had one I'd ask $3000-3500
#5142 1 year ago
Wow an LE with topper just went for 11700. Maybe the topper is coming down with everything else(mostly hoping)
I want a topper for my LE but not at 3k. I did that for r2d2 and regretted it.
#5143 1 year ago
Quoted from mbrave77:
I thought it would’ve been more.
#5144 1 year ago
I was told to post here... I have a mint/sealed NIB BKSOR Topper that I can bring to the Texas Pinball Festival. I did NOT pay MSRP and am into it for almost my asking price also. I bought this for a machine and just never got around to installing it because of COVID. My BKSOR was traded and I figured I'd get an LE some day... but that was before prices went nuts on them.
$3000 cash in person. Works great because you get to the topper in person and don't have to worry about shipping.
First come, first served. These are super rare and THE best topper in pinball (my opinion).
#5145 1 year ago
I really thought about buying that game, just taking the topper for myself and then selling the LE seperately. Id love to have the topper(ive owned it in the past when I had a premium), but 3k is a bit much. Id probably buy one if I saw for 2500 ish tops just because my LE looks lonely without it. And BK and R2D2 could talk to eachother.
#5146 1 year ago
Installed a catwalk for the black knight to guard the entrance. This is an awesome game.
#5147 1 year ago
remind me this :
#5148 1 year ago
Quoted from RipleYYY:
remind me this :
Lol
#5149 1 year ago
Autolauncher .. Grr. BKSOR LE. Second one. First was a covid rental second was an LE with topper. This thing has been rock solid aside from the BK target moving.
Recently the auto launch stopped randomly making it all of the way up. Fingers on the ball look good. Polished the shooter lane. Balls are new. Just replaced the coil and sleeve. Same thing. Mech seems solid. Same as AIQ. Even tried the slowmo on the cellphone but it seems to shoot straight up with no ricochet.
Manual plunge is fine. But that really doesn't play into any of this. WTF am I missing?
#5150 1 year ago
Quoted from SDVmnt:
How is the power setting in the software? I have turned mine down from factory quite a bit. Also check line power?
$ 69.99
The Pinball Scientist
Space Coast Pinball
9,500
Chicago, IL
Trade
Machine - For Trade
Olympia, WA
$ 1,499.00
Paradise Distribution
PinEffects
$ 16.00
System-J
8,500
Reading, MA
Hookedonpinball.com
$ 59.95
Hookedonpinball.com
9,700
Smithtown, NY
Lighting - Backbox
Myth Pinball Parts Shop
$ 160.00
Sparky Pinball
$ 6,999.99
Pinball Pro
$ 110.00
arcade-cabinets.com
Filament Printing
$ 6,999.00
Classic Game Rooms
Great pinball charity
Pinball Edu
