Quoted from Sorokyl:The guy above did better than professionals.[quoted image][quoted image]
Thanks. It's probably because I put more effort into them than the "professionals".
I bought a set of drop target decals only one time; for my first pinball machine (judge dredd). I was very disappointed in them, $15 and I took one look and new I could do better.
Quoted from setzkor:What kind of paper do you print on, and then are you putting mylar over it?
Here's my typical process: I find a suitable image and re-touch it until I'm satisfied with it.
I then do several black and white test prints with varying sizes until I get the image to the desired size.
Then print out on glossy photo paper. I use an Inkjet printer, nothing fancy. Select "best" for the image qaulity and "glossy photo paper".
You can print out directly on sticker paper but the colors aren't as vibrant.
I then take sticker paper, spray it with 3m spray adhesive (I think the one I use is for fabric). Let it get tacky....15 seconds. Then lay the photo paper over it....image side up of course. Wax paper over the image and then I put several thousand dollars worth of my old text books over the top. I let that sit for a day.
Next day, I cover the image carefully with packaging tape. Lay it down slowly so no air bubbles get trapped. I dont use mylar because I found it doesn't go on as clear.
All that's left is to cut out the image.
