Since I got mine I've discovered a few things. The deflector plate in the Death Star causes a lot of rejects, similar to the IJ scoop deflector, so I've put a felt pad on there for now and ordered some drop dead foam. Hopefully that does the trick. I'd rather not mess with bending the plate, but that'll be the next step if necessary.
Also, I see just about every Star Wars has wear on the side rails right above the lock bar. This is caused by the loose lockbar that I presume is common on all DE machines. The solution here is pretty simple, take the lockbar out and bend the tabs forward a little bit with a crescent wrench. If you bend too far, it won't latch, but I got mine just right and now it's nice and snug. I hate having it move around while I'm shaking the machine. Using some black paint to cover the wear spots.
I also tried taking off the rubber half-posts at the top of the slings, to give it more bounce like most other games. But alas, this seems to lead to quicker outlane drains, so I put them back on. So if you want to make the game harder, there ya go. Put clear rubber on the slings (2.5", as they don't make 2.75" clear) and it looks great. I love clear rubber on slings.
Also found it odd that there are nails (?!) under the slingshot plastics. This does a great job of scratching the graphics. There's a metal post under there that scratches a different spot as well. So looks like you need plastic protectors before installing new ones.
Would also like for someone to produce a 44 flex fast color changing LED to go under the light saber insert. If there's already one out there that I'm just not aware of, I'd love to know about it.
EDIT: Maybe this would work, http://www.cometpinball.com/product-p/1fluxrgb-w.htm
On a final note, getting the double jackpot is harder than I thought it would be. Tough game!
