(Topic ID: 72482)
Data East Star Wars Club...Members & Fans Welcome.
By MustangPaul
10 years ago
  • 4,774 posts
  • 414 Pinsiders participating
  • Latest reply 16 days ago by Greyhound
  • Topic is favorited by 199 Pinsiders
There are 4,774 posts in this topic. You are on page 96 of 96.
#4751 74 days ago
What I did - I taped a cereal box circle on the inside of the Death Star. The circle was the same size as the smooth circle that is at the top of the dome. Then I put a small amount of baking soda in the hole that was there. I then dripped liquid super glue over the baking soda. This enclosed the hole. It dries in less than 30 seconds. After that, I turned the Death Star over, removed the taped in circle of cereal box, put a very thin layer of baking soda in the circle at the top of the dome and dripped more super glue over that. After the super glue, I drizzle baking powder over the wet glue. You only want to make it as thick as the Death Star, but if you get too thick, you can sand it down. I drilled a hole in the new formed plastic, and put it on the machine. I didn't even paint it. All in all, it took less than 1/2 hour.
Sorry I didn't take more pictures, but I was so excited to get it done.
Inside (resized).jpegInside (resized).jpegOutside (resized).jpegOutside (resized).jpeg
#4752 74 days ago
This is the finished product in game. It works better than it ever did before! And is much stronger.
#4753 59 days ago
There is a lot of knowledge I've accessed here during my SW restoration so thank you all. I've wrapped up my playfield restoration and have an issue with the double x-wing targets. The bounce back from these 2 targets is insane. The ball will bounce over the flippers, hit the glass and drain or into the shooter lane. It should be noted that when I replaced the 2 targets I kept the metal angle back brace brackets (535-5116-00). I also did, among many things, a full flipper rebuild with new coils etc.
Has anyone else had this problem or can make recommendations on a fix?
#4754 59 days ago
Quoted from Greyhound:
I had issues with the targets I used bending backward, causing air balls. They needed to have some sort of brace put on to keep them from bending, but I sold it quickly before I had a chance to fix it.
#4755 59 days ago
It was recommended that I keep those braces behind the targets for that reason Kawydud . I'm wondering if I can deaden them somehow. Maybe new flippers and coils are too strong.
#4756 59 days ago
Did you add the firm foam backing sponge?
#4757 58 days ago
Quoted from vec-tor:
I have not. I see the manual calls for 626-5006-00. It looks like PL has something close
https://www.pinballlife.com/target-backing-foam.html
#4758 58 days ago
https://www.marcospecialties.com/pinball-parts/626-5029-00
This is almost OEM from sega manual.
#4759 58 days ago
Thanks for the help vec-tor ! I cut some to fit with some 3m backed foam to those dimensions. Did the trick. Added to my cart for the next Marco order.
#4760 58 days ago
Excellent.
#4761 45 days ago
I managed to make my machine boot, and I'm getting close to the goal to have a perfectly working game but now what I experienced is very strange: the display runs with very low FPS. At the skillshoit the TIE fighter is just appearing here and there, like instead of the normal approx 6-7 FPS it runs just 2-3 frame per second. Any idea?
#4762 45 days ago
Quoted from mark532011:
woohoo, just joined the clubs....
wait, there are 92 pages to wade through????[quoted image]
Without seeing a video it's hard to say, I do know it's not exactly "fluid" video, so it may just be normal. It could also be that the ROM is getting old and could be due replacement. I suppose it could also be a power supply issue, which these Data Easts are known for having issues with. Poor power supply voltages can cause weird anomalies to happen, not saying this it it but could be.
#4763 45 days ago
Quoted from STLOkie:
I have a new power supply board, voltage is perfect now. ROM is new, CPU new, RAM new.
I know how it should be, since this is one of my favourite games. I will try to make a video tomorrow
#4764 30 days ago
maybe a long shot, but any of yall have a spare of the boba fett plastic that lives up by the death star?
tryin to avoid buying a whole set of plastics just for one exploded piece haha
#4765 30 days ago
Quoted from Eduardolicious:
I dont have a spare but I have a scanned in image that can be used to create a replacement if you make one.
#4766 30 days ago
I was able to add a 3rd support spacer by the legs. It stopped the plastic piece from breaking.
#4767 29 days ago
I'm hoping someone can help here. As part of the restoration, I was hoping to partially disassemble the Happ shifter to clean and replace the decal. According to the diagram the handle should be able to be removed from the black plastic knuckle, but I've had no luck. Thanks!
2024-06-12 16.47.53 (resized).jpg2024-06-12 16.47.53 (resized).jpg2024-06-13 10.41.51 (resized).jpg2024-06-13 10.41.51 (resized).jpg
#4768 29 days ago
Ah I got it. Tug hard lol. Silly but apparently you have to entirely disassemble this mech in order to put a new decal on it.
#4769 25 days ago
Hey all,
I’m looking to replace the dome of my R2-D2. I picked up the replacement chrome dome that’s available on Marco but I’d like to find a replacement that looks more like R2. Plus, the clear blue piece that fits in the dome is cracked. Does anyone know of a better replacement?
Any help is appreciated.
A
#4770 25 days ago
I made a clear plastic protector that goes over it.
#4771 24 days ago
Quoted from toolbox195:
Hey all,
A
I am interested as well. I was thinking I could 3d print one but I don't know how well the chrome spray paint works and if it would look decent.
#4772 22 days ago
Heu Guys, I am looking for some advice on how to proceed. Working my way through my Star Wars, I noticed the R2D2 does not move up and down (dance.)
I thought it might be a bad coil (or diode) as it does not move in the diagnostics coil tests, but checking the wiring with a meter I am not getting any voltage to the wires when the diagnostic fires it.
Looking at the schematic, I am thinking my next step would be to check and see if the Brown/Black wire from Pin 1 goes all the way to the coil successfully.
after that, replace Q30??
Screenshot 2024-06-20 143529 (resized).pngScreenshot 2024-06-20 143529 (resized).png
#4773 22 days ago
after that, replace Q30??[quoted image]
1) do a quick gnd test on the anode side, Browm-Black wire.
if solenoid activates, then gnd test Q30.
#4774 16 days ago
Hi Guys. Can anyone tell me how to remove the button (2) from the end of the Shooter handle?
$ 14.95
Metal-Mods
$ 45.00
Pixels Arcade Games
5,000 (Firm)
Phoenix, AZ
$ 17.50
Pinball Invasion
Lenticular Designs
$ 48.00
Pixels Arcade Games
€ 130.00
Pino Pinball Mods Shop
$ 32.00
Slap Save Creations
$ 18.95
$ 18.95
$ 18.95
$ 18.99
Tools
FlipMods
$ 85.00
Playfield - Plastics
$ 9.99
$ 99.00
Pixels Arcade Games
$ 85.00
$ 27.95
$ 185.00
Sparky Pinball
$ 9.95
