Hi chaps,
I have a TZ that requires a complete clock assembly as it is missing. Does anyone know where I can buy the whole thing?
Cheers
Nevermind found the motor
https://www.thepinballwizard.net/electronics/electrical/twilight-zone-clock-motor-a-16652/
The housing is not available anywhere AFAIK
Full set and partial set of gears are at Marco
Face and face cover: Marco
Back : Marco
https://www.pinballspareparts.com.au/parts-by-machine/bally-parts/twilight-zone/03-8833.html
Housing here
https://www.pinballspareparts.com.au/01-11337.html
Base
https://www.pinballspareparts.com.au/03-8834.html
Back
https://www.pinballspareparts.com.au/03-8838.html
https://www.pinballspareparts.com.au/03-8837.html
Hands
https://www.pinballspareparts.com.au/01-11595.html
Ball stop
https://www.marcospecialties.com/pinball-parts/CLK001P
Board
https://www.marcospecialties.com/pinball-parts/31-1751-3
Decal
https://www.marcospecialties.com/pinball-parts/03-88XX
Gears
https://www.marcospecialties.com/pinball-parts/A-16652
Motor
https://www.pinballlife.com/twilight-zone-clock-lens.html
Clock lens
https://www.marcospecialties.com/pinball-parts/02-4714
Hand pin
Easy not listed
2 bulb sockets 2 leds 2 bulb caps (1 red 1 yellow) a few e clips and 8 screws
Hard parts
You need this A-16653(the shaft) and the rods that hold the gears and the wire harness
A used one if available will be way cheaper a nos one would be about the same or more then the build option
Quoted from PinballAir:There is one on ebay: NOS headed for the strasphere
Don't see them too often anymore. I was lucky and found one a year ago for my TZ here. Greased the gears, put in a new LED clock board, swapped faces ( I have an early sample TZ ). Hopefully good for another 28 years.
There wasn't enough left of my original clock anymore to keep it going. Literally every part was worn/shot. Better for my players to be able to start over fresh.
A day and a half left.
ebay.com link: Twilight Zone Pinball Machine NOS Clock Assembly
I own the game and was lucky enough to repair my clock.
If you had to build one from scratch, this is still kind of a deal once you figure prices of parts, shipping costs, customs charges and waiting/aggravation factor.
If you MUST have your game bone stock , again there it is.
Question: Is it important to return the hands to the original position? I took mines apart and did see that it is suggested to return to original….
Quoted from Gorgar666:Question: Is it important to return the hands to the original position? I took mines apart and did see that it is suggested to return to original….
Uh, if you don't, the hands will never align properly.
Unless I'm misunderstanding the question..
Quoted from Coyote:Uh, if you don't, the hands will never align properly.
If the hands where removed at 3:16 do you need to be placed back at 3:16? I don’t know what the time was originally…
Quoted from Gorgar666:If the hands where removed at 3:16 do you need to be placed back at 3:16? I don’t know what the time was originally…
Oh, BIG YES.
If you don't remember what time the clock had, then follow the manual, and put ALL the gears in one by one, following the instructions. This will verify that all gears are aligned properly. (Following the directions, when you reassemble all the gears, the clock will be as midnight when you're finished.)
Quoted from Coyote:Oh, BIG YES.
I just ordered the manual thank you!!!
Quoted from Gorgar666:I just ordered the manual thank you!!!
No worries! PDF would have worked too, if you're in a hurry.
Quoted from Coyote:PDF would have worked too,
https://www.ipdb.org/files/2684/Bally_1993_Twilight_Zone_Operations_Manual_OCR_searchable.pdf
Quoted from knazzo:If still needed, i have a complete original Twilight Zone Prototype Clock Assembly for sale.
Prototype or SAMPLE?
Quoted from knazzo:It has the original Prototype Clock Decal.
Can you get a pic? All the prototype decals were replaced by the white clock faces during development of the game, though it's possible one or two got out.
Quoted from knazzo:You are right, it's a sample clock. Decal is the white one, prototype is different.
Damn, thanks for checking! I have an actual proto playfield, and was REALLY hoping you actually DID have the proto clock, because they'd look fantastic together!
Coyote
I always thought that the prototype clock face was white.
What is different about the prototype clock face?
Chris Hibler - CARGPB #31
http://www.ChrisHiblerPinball.com/Contact
https://www.youtube.com/c/ChrisHiblerPinball - My YT Channel
Quoted from ChrisHibler:What is different about the prototype clock face?
From a Pinside post.
Pinside_forum_5186633_0 (resized).pngQuoted from LTG:From a Pinside post.
LTG : )[quoted image]
Neat. I’ve never seen that before.
Http://chrishiblerpinball.com/contact
Thank you for checking out the PinWiki - http://www.PinWiki.com/
Quoted from ChrisHibler:Neat. I’ve never seen that before.
Yeah - because the clock originally had controlled (lamp matrix) lamps in it, if I recall right they were going to have the clock me 'more interactive' - but penny pinchers, yadda yadda.. IMHO, while it would have been neat, that color pattern/scheme, for me, doesn't fit well with anything else on the game.
Quoted from Coyote:Yeah - because the clock originally had controlled (lamp matrix) lamps in it, if I recall right they were going to have the clock me 'more interactive' - but penny pinchers, yadda yadda.. IMHO, while it would have been neat, that color pattern/scheme, for me, doesn't fit well with anything else on the game.
That prototype clock face looks like dookie. So does the white one IMHO.
The production version is the best, again, IMHO…..
Agree. Neat to know but I would not choose that clock face.
This page was printed from https://pinside.com/pinball/forum/topic/twilight-zone-full-clock-assembly and we tried optimising it for printing. Some page elements may have been deliberately hidden.
