Hey guys, having an issue with my Ripley's.
The main issue is that the game is resetting randomly. Sometimes 20 seconds in, sometimes 5 minutes into a game.
Side issues: it's randomly scoring points. At first it would score infinite points usually on ball 3 when it pops into the plunger lane and sits on that switch (until it moves off), but doesn't do it on your first or second ball. After reseating a bunch of cables in the backbox now the first ball won't even pop up into the lane when you start a game and the monkey magnet thing starts scoring infinite points as if the ball is moving over that magnet.
Tested all the transitors on the whitestar board and none are shorted. Looked for something burnt up under the playfield, but all looks good (whole machine looks real good). Tried reseating all the cables on the CPU and Whitestar boards (made issue worse).
One more note: the last guy to own the machine cut off the ground pin on the 3 prong outlet plug (this couldn't just be a grounding issue, could it?)
Thanks ahead of time!
