I recently (finally) managed to get my hands on a lotr in good condition.
The only issue was the Balrog motor is not working properly.
When I turn on the machine, the motor instantly starts spinning and it never stops.
The 2 balrog switches weren't registering but I fixed that (broken wire) and they now both register. That didn't fix the issue though.
When I opened up the relay, I noticed the relay switch (which causes the motor to turn the other way around) is never activated. When I activate it manually, the motor turns the other way but again it never stops.
During the relay switch test however, the switch works and the relay lets the motor turn the other way (maybe that switch only goes of when the balrog is supposed to swing? In that case, the issue that the motor just won't stop might be something else I'm missing).
I checked the fuses to be sure and there was one fuse broken but it was the ring magnet fuse so probably nothing to do with this issue.
Can't seem to figure out why there's never a 'stop' signal going to the motor and if it's a motor issue, relay issue or something else completely..
Does anyone have any great ideas about this issue? It keeps me up at night
