I received a DOA Firepower that a lady from a thrift store wanted working. I started by replacing the 40 pin. I got a game working with no sound or speech. Rebuilt a sound board and speech board and all was well. Played a dozen games, left it on in my garage for a while, no issues. I dropped it back off to the owner and she said she had it on for an hour and smelled something, displays were flickering and she shut it off.
I got there and seen a solenoid fuse was blown right away. So I checked sweep on the coils to make sure none were locked up and ohmed out each one and all were fine. Replaced the fuse and had a functioning game, displays were all on except the credit/match field. Display test shows that display and segments are working but in normal gameplay nothing is being displayed in that field, it’s simply blank. You can see a little orange dot at the bottom of the display if you look at it from the top or side.
She wanted it on quarter play so I made it quarter play via the settings and everything was working fine when I left the day I dropped it off. The lockout coil is not wired in. Now after the incident, the knocker for credits isn’t even registering. So I placed it back on free play for her and told her I would do a little research.
