In the process of trying to sell this game my original topper got crushed. Not a happy camper but stuff happens. I looked for a replacement and none to be found. I had seen a post here about someone else replacing one with a DIY version so I figured what the heck. That post talked about getting some plastic and bending it with a blowtorch. I figured I would see what I could do and headed over to a local plastics supplier with the old part with a few plans in mind.
Plan A was to see if they could make me a new one. As it turns out they could, but it would be several weeks and I have this machine for sale and didnt want to wait that long. Most likely they would have made some type of mold and thermoform the plastic to fit. I didn't ask about a price, it sounded expensive. Maybe if it was for a run of them and they could be sold it might make sense, but I'm not looking for that.
Plan B was to get some plastic and bend it into shape, similar to the post I referenced here. They had the red plexi but the owner said that trying to bend it by hand might not work too well. The guy suggested using a pretty thin polycarbonate plastic that would bend easily. All I had to do was figure out a way to get it to stay in shape and color it red. A piece about 2x4 feet cost me 25 out the door.
I'm used to working with aluminum and had some channel molding and some other bits and pieces kicking around. I swung by HD and got some fairly thin flat stock as well. When I got home I set to work making the two ends and connected them with some L shaped pieces that I got by cutting the U channel in half on the bandsaw. The flat stock was pretty easy to bend and I used a sanding drum of about the same diameter as the old topper to put the half circle bend in. Before I did that, I put a 90 degree bend in to help align the upright parts with the L base. I pop riveted those parts together and thought about it some and added a piece in the middle for added support.
I sprayed the frame as well as one side of the plastic with some Krylon red for plastic I happened to have around. To attach the plastic to the frame I applied some double sided tape and then attached the painted side facing in. Keeping the paint on the inside would prevent anything from the outside scratching it. I added some pop rivets in about 3 spots on each side to give it a bit more hold over time. SInce the original had clear ends, I added some clear plastic to each end that was cut and shaped to fit and then glued in. Finally I added some silver tape on each end to mimic the original topper.
The topper was attached back to the top and unless you knew it was DIY, you wouldn't notice it being different.
