Make sure first that it's CLEAN on the underside, as wiping it down. I can't imagine that anything other than water would be needed on the underside, since any crud on it would just be metal dust lofted by the heat from the bulbs, like the crud on any insert.
Assuming you've done this and come to the conclusion that the upper surface is the problem, you'll need to polish it up - polishing clear things so they come out transparent is tricky, as I'm sure you know. You might be better off trying to find someone selling a brand new repro - it's not a hard part to fabricate with a laser cutter, so i'd be stunned if it wasn't available. As usual, trying to find it in marco's web storefront is hopeless.
