Thank you! The white, stock bats just made too much sense with the white of the water splashing against the raft and the white of the upper playfield river. The blue rubbers go well with the blue of the playfield and theme.
Received the Mantis metal switch-mounting brackets. Two will get installed and two will be stored. The double gate will only be half-used, as the MRS for the Insanity Falls ramp reads the ball 100% since the neck of the ramp is narrow after the entrance.
Mantis
Metal
Mounting holes look good. Screws went in at a slight angle but then rested flat after straightening out during install.
Mounting
Switched out the Bluffs / Canyon Ramp "Main" MRS and added in the 842. # 01-9476-2 Switch Bracket, 843. # 5647-12693-21 mini sub-micro switch, and subsequent parts to have the stock, physical switch so the ball movement will be read 100% of the time there. This is seen in the previous Bigfoot diverter GIF triggering the log movement. Also, added in the Pinball Decals plastic protector to keep the ball down and protect the new switch.
Plastic 1
This piece needed some minor adjusting on the position of the screw holes
Plastic 2
Mounted the protector above the stock plastic (no sense in deterring the ball from getting a little air at the turn in the ramp)
Plastic
Switch moves freely and tested with a ball before finalizing the install
Switch
MRS was nice, but this is how it has to be for this switch
Done
Insanity Falls / Rapids "Entrance" with the double gate installed on the mini playfield, but still using the MRS
Entrance
The Bluffs / Canyon Ramp "Entrance" switch just needs the gate wire form (in transit) for it to be finished, and then the switches are all done. The switch is necessary to trigger the Bigfoot diverter, as the ball can whiz under the Canyon Main switch and beat Bigfoot moving the log. Both switches on the Canyon ramp trigger the diverter movement, which is needed for the ball to be properly guided.
Here is another good lesson learned - the sunlight-colored light strips from Comet match their frosted sunlight bulbs only if the light strip is clear and not frosted.
Frosted Sunlight
Frosted Sunlight
Clear Sunlight
Clear Sunlight
Comet, with their great customer service, helped make this correction
