Pulling my hair out a bit trying to get the vault eject to consistently feed around the orbit to the right. I've tried bending the scoop hood as suggested, loosened the scoop from underneath and tried shifting the angle a bit (not much play there, but tried), have messed with the power, changed the game slant up and down. Best I can do is maybe 50/50, and most of the shots that do make it to the right upper flipper are anemic - it barely makes it around, slows down and feels crummy. I'm a perfectionist, I'm stubborn, and it's making me nuts.
If you get a consistent smooth feed to around the orbit from the vault, I'd really, really appreciate ya pulling the ramp (only takes a sec) and taking some shots of that scoop so I can try and figure what's dif on mine. Under the playfield too.
What I really think may be the main issue is inconsistent position of the ball in the scoop itself when the plunger fires. Here's a video of "worst case scenario" :
It's that rattle and bounce into the lane that kills the feed, but it's very inconsistent. If you look down in the scoop itself you'll see the ball rattling around before the plunger fires - meaning it probably hits the ball differently each time, making the trajectory inconsistent outta the scoop. The scoop design itself looks like it may have been built with that in mind actually - never seen one like it anyway, kinda interesting:
There's a hole floating over the eject plunger, with a wishbone-shaped leaf micro switch to trigger it. I'm thinking they put the hole there to try and settle/center the ball for consistency? No idea why they'd build it that way otherwise (would love to hear the story there for my own interest regardless). Seems like adding a delay after trigger before firing the coil might give the ball more time to center and improve consistency regardless?
Anyone with suggestions to get this feed consistent, please shout. I've dialed in everything but that (and I had decided to just ignore it until I discovered the secret skill shot :p)
Oh, and if you need motivation to remove the two screws to take the ramp off, you prolly want to put some mylar on the edge here for posterity, mine was getting pretty chewed up (I suspect there will be some there in future builds, gave AJ a heads up when I noticed):
