(Topic ID: 260080)
Vendor Decal Removal
By The-Who
  • 11 posts
  • 8 Pinsiders participating
  • Latest reply 4 years ago by The-Who
  • Gigi Gottlieb, 1963
#1 4 years ago
I picked up a Gottlieb Gigi today at the flea market. Everything works great other than needing a good play field cleaning/waxing and a few bulbs.
The the address was scratched out on the vendor label, but the rest of the label remains. How is the best way to remove this?
E31C368F-7B5A-4297-B65E-2877548DE10A (resized).jpegE31C368F-7B5A-4297-B65E-2877548DE10A (resized).jpegC54575B8-2D69-49C2-94C0-5828CC3B351D (resized).jpegC54575B8-2D69-49C2-94C0-5828CC3B351D (resized).jpeg6AD9EFF0-FF6F-4D2B-B85C-02A7AB5304AA (resized).jpeg6AD9EFF0-FF6F-4D2B-B85C-02A7AB5304AA (resized).jpeg85556728-ABB8-495F-AD0B-484000355A72 (resized).jpeg85556728-ABB8-495F-AD0B-484000355A72 (resized).jpeg967B54B3-D919-42DF-861B-FD1985986E7C (resized).jpeg967B54B3-D919-42DF-861B-FD1985986E7C (resized).jpeg
#2 4 years ago
Goo gone or goof off. Test in an inconspicuous area in case it reacts badly with the paint.
#3 4 years ago
Looks like a water slide decal.
#4 4 years ago
Quoted from YeOldPinPlayer:
I’ve had it covered in a coating of Goo-Gone for awhile, but it isn’t doing much. I’ll let it soak some more.
Thanks for the prompt reply........Denny
#5 4 years ago
The "flea market"? Where?
I wish I could find a nice wedgehead at the local flea market!
#6 4 years ago
I find WD40 really good for sticker removal-it may take a few applications and some appropriate rubbing. If you are doing it on the machine make sure you have protective cloths to prevent any runs on the pdf.
#7 4 years ago
Quoted from wayner:
I second this. It does a good job at removing the adhesive without removing the paint. I've removed several operator decals on ball aprons with it.
#8 4 years ago
If the WD 40 doesn’t work, I’d moisten the edges with mineral spirits and gently work with a new single edge razor blade. Good Gone is ok but Goof Off is basically benzene and xylene and will eat into the paint.
As a painting contractor I’m constantly having to remove stickers and tape. It all depends on the surface and how strong the adhesive is. Either way, you might lose some of the webbing.
#9 4 years ago
It looks like a water slide decal. What would a person use to remove that? Water?
#10 4 years ago
Take that apron off of the game. When using any chemicals or water near the playfield, and the inside of the cabinet.
I would try to soak the apron in warm water. To soften up the decal. the enamel paint should hold up to the water. The real problem is the webbing, it does come off fairly easily. Looking at the scrape marks, it appears some paint loss has happened already.
#11 4 years ago
Quoted from Sea_Wolf:
It took awhile, but this approach worked. Applied several rounds of Goo-Gone with my finger while carefully scraping with new single-edged blades. Gave it a light buffing with some polishing compound afterwards and it turned out pretty nice.
Thanks for all the suggestions.
BABF8F27-EA9C-4449-874E-46CCC6B507B8 (resized).jpegBABF8F27-EA9C-4449-874E-46CCC6B507B8 (resized).jpeg
1,099
Greenville, SC
Cabinet Parts
Space Coast Pinball
This page was printed from https://pinside.com/pinball/forum/topic/vendor-decal-removal- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
