The left flipper on my NF seems weaker than the right one. The right one is very loud as the plunger comes against the coil stop, but the left one does not make near the noise and is spongy. I rebuilt both flippers using all new parts, including plunger, linkage, sleeves, coil stops and and new correct (identical) flipper coils. I replaced the left flipper opto board just to see if that had any affect but that did not seem to make any difference and the optos are registering o.k. in diagonostic tests(switch levels.) I checked to make sure there was no binding. Both the left and the right flippers feel the same when i operate them by hand from the playfield. I checked the EOS switch and it is set correctly, opening only at the end of the flipper stroke. Any ideas, thoughts, comments on what I should check next?
