I have some alkaline damage to a couple of the SRC's above the batteries on my F14. I've searched around and found out that SRC's aren't readily available but I can use regular SR's and just cut off pin 10. Everything I've read though, says to use a 1K resistor (most of the threads I've ready have people replacing SRC6 which is a 1K resistor), but SRC's 1-5 are 4.7K ohm. I haven't found anything referencing replacing these with a 4.7K ohm resistor but that's what I'm leaning towards. Can anyone confirm if I should use 1K or 4.7K ohm resistors?
The article on pinball rehab mentions SRC's 1-9 can be replaced with SR's but says to use 1K resistors, I think this is where my source of confusion is coming from:
Thanks,
Mike
