Archived ad
Pinside keeps a record of old ads in its Market Archive, for historical purposes and as a price reference. This ad has been ended by its seller and is now archived.
for sale
New Repro Bally / Stern Lamp Driver Board with LED support
Added: 2017-04-03 22:00:00 UTC
• Re-listed: 2 times (July 18th, 2017)
• Ended: February 11th, 2018
Condition: New
Price
$ 15 (Firm)
Price is firm
Item description
Hi Pinside
I have new Bally / Stern replacement Lamp Driver boards for sale. It works and fits just like the original lamp drivers but adds LED lamp support. A 0.100" kk molex connector labeled J5 gets connected to the switched illumination bus (feature lamps positive connection) when the loading resistors(RL designations) are installed. This adds support for LED lamps so they do not flicker. If the RL resistors are installed, J5 must be connected to the switched illumination bus or a ground return leak through multiple resistors will happen.
Fully assembled Lamp Driver Boards are available in limited quantities for $90 shipped in the USA. Includes the J5 harness.
If you like a DIY project, blank PCBs are available for $15 + $3 to ship. You would need to source out the parts and assemble the board yourself. Part costs should be around $15. Tayda for the SCRs, connectors, and passives. Futurlec has the decoders ICs for $0.85 ea.
The PCB has multiple package options for many components. The 4514 decoder can be SO24 or DIP24 package. Most resistors have SIP network, DIP16 array or discreet options. See the BOM here
http://nvram.weebly.com/uploads/5/4/2/5/54255141/bally-stern_ldb_bom.pdf
Use my website http://nvram.weebly.com or message me here.
Andrew
Contact
Note! This is an archived ad. No longer for sale!
Listing result
The seller marked this ad as "not sold". The item did not sell through Pinside so there's no listing result.
