So all of my Mata Hari's lighting except for the back box and coin door usually doesn't work 100%.
From what I gather from doing searches, I need to replace the AS-2518-18 board (and the connectors that plug into it, right?)
New at this:
A) Based on the pictures below (those are the plugs that plug into the 2518), is this correct? Is there something I should test first?
B) Assuming this is correct, what do I replace the AS-2518-18 board with?
C) I assume this is a fairly common procedure. Anyone have a step-by-step on how to do this?
thanks!
