Greetings guys.
I’m at a loss on this one. During a game when the ball lands in the upper left hole, the hole switch activates and scores points but the kicker doesn’t fire, so the ball just lays in the hole scoring points. Here’s what I’ve done so far:
On the schematic the left hole kicker coil is in circuit with the switch on the I relay (Left hole relay) with the green/red wire which I checked and cleaned and the I relay activates as it should when the hole switch closes.
Next I got out the jumpers and jumped the kicker coil and nothing. Couldn’t believe the coil was bad (not burnt) and when tested the resistance out of circuit, it tested good along with the right kicker coil. Then I just swapped the right kicker coil with the left and it made no difference. Left kicker still not firing.
So knowing both coils are good I trace the green/slate wire from the left kicker coil to the Jones plug and thoroughly cleaned the male plug and the female receptacle where the green/red wire comes in and nothing.
For reference, the coil plunger and the kicker arm move freely when I manually move them. I’m obviously missing something and appreciate any ideas.
Danny
