Dear Lloyd
Our resident pinball guru Lloyd Olsen answers Pinside readers questions!
Sunday January 12th 2014
Hello Lloyd,
My IJ suddenly started resetting when both flippers are pressed at the same time. Not always, I can get through one ball sometimes, other times it resets pretty much immediately. I have read the pinwiki article and will go through that process but before I do I thought since I had made some repairs to the machine that I could have done something that caused the issue.
Changes:
1) Glued the right front cabinet corner which had become separated.There is a ground wire that comes up the corner.A continuity test indicates that it is connected.
2) Replaced the gun handle with a new one, so had to disconnect the switch and re-connect.
3) Replaced both ball trough opto boards.
4) Replaced the lamp board under Willy and Shorty
5) New lockdown bar and side rails (doesn't seem likely as a cause)
Also started step one of the pinwiki process and the machine does not have an auxiliary socket....
Thanks,
Mr. Ford
This page was printed from https://pinside.com/pinball/forum/topic/ij-resets and we tried optimising it for printing. Some page elements may have been deliberately hidden.
