When you use a jumper, it doesn't matter what switches control a coil. The reason you run a jumper wire directly from the 25 volt fuse to the coil lug is specifically to bypass ALL of the switches. When you jumper a coil this way, it will ALWAYS energize. If it doesn't energize, either:
- the power is off
- the coil is bad
- you didn't do the jumpering correctly
- the black coil return wire is disconnected somewhere (extremely rare)
Since neither AX coil fired when you jumpered it, it's possible you didn't do the jumpering correctly. Try this: jumper some another coil that you know is good (like a bumper that is working normally) to confirm that you are jumpering correctly. If you are, the known good coil will energize.
Once you are sure you are doing the jumpering correctly, try jumpering the AX coils again to see if they energize.
To answer your question about the switches: the 10, 100, 1,000, and 10,000 score unit runout switches as well as a switch at motor position 2B, all wired in series, are what trigger the AX coil to energize to take the game out of reset. On your schematic, this is the coil just below and slightly left of the motor symbol that is marked "AX" RESET. Follow the wire coming off this coil to the right and you will see each of these switches, one after another, on the wire.
- TimMe
