FYI, I am new to EPROM burning. I'm assuming it works like load code on a microcontroller (with a few differences).
I have a G540 USB eprom burner
Using a 27C801 (athough a 27C080 was specified). I believe they are compatible.
Configured app to recognize ST-27C801 .
Erased EPROM, loaded ROM in software app, burnt rom. Software did verify and everything looks ok.
Put in pin (carefully), and when I turn it on, I get a few moment of silence followed by a repeated beeping sound (like an alarm).
Pulled ROM out and put in original and it worked ok.
Tried same process again and got the same results.
The ROM chip is larger than the original, but I did not see any jumpers on the pin to set it to use the larger ROM.
ROM size is 1MB.
Questions:
--If anyone is familiar with the burn app for the G540, what settings should I use for "fill blank area with" as well as other settings. I was using the defaults.
--Do I always need to change jumpers on the board in the pin when using a larger ROM(In my case, the game is Demolition Man)?
--Any thoughts on the "beeping sound" on startup? Is it a common result?
Thanks for any info.
