Model: Williams Hurricane Pinball 12835 power supply.
My "test/config" button was not working on my coin door. Is it related or not, I dunno. I found out that it was connected on the 6.3v J119 connector on the power board. I tested the connector and:
J119:
Pin 1: 6.3v
Pin 3: 1.0v uh oh, supposed to have 6.3v
Came back to the coin door interface J2:
Pin 1: 6.3v
Pin 2: 1v uh oh but make sense
Went to see where J119 was getting his power from and it's from J115 on the power board which itself gets his power directly from the transformer/ps... The J115 12pins connector is separated in two connector of 6 pins each on my pinball. Pins 12-11-10-9-8-7 gives 0v and pins 6 to 2 gives 6.3v or so.
My question: How can I test this 9 pins connector from the transformer with the yellow wires? I mean, I have VERY basic knowledge of how to test and I tried to test any of the pins on the 9 pins connector on the transformer by grounding myself on the frame of the pinball, I have a reading of 0v on all of them but pins 6 to 2 works so for sure i'm not testing properly
