Quoted from MarkG:I suspect it's the other way around: the Score Motor is running because the Outhole relay is stuck on. Is that the case? Is the Outhole switch stuck closed or shorted?
The outhole switch does not appear to be stuck on or shorted.
The outhole relay 'pulses'. As the score motor rotates, it activates and fires the outhole kicker. Then it unlatches. As the motor rotates, it actives again. Then unlatches, etc.... It is not continuously stuck on.
The 'Bonus Score' relay on the mech board also pulses. Again, I notice if I put a piece of paper between the following switch, the motor will again stop:
freedom1.pdf
Also, if I insert a piece of paper in the following switch on the Bonus Unit under the playfield, the motor will again stop. This switch is normally open in game over mode, but when I start a game it closes. When its closed after pushing the credit button and starting a game, if I put in a piece of paper between the switch contacts the motor stops:
freedom2.pdf
