Took my cabinet apart to tumble parts and paint and didn't take any pics. I have everything back together but cannot figure out the lock assembly. Can someone take a picture for me it's a mr and ms pacman.
I did the same thing and put it back together based off how I guessed it worked. Here are some pictures, I assembled them wrong in the photo so look at the text blow the pictures to confirm the order. Obviously these might not be correct. This is a bally wide body, I'd assume they are the same. I used silicone grease to ease the slide mech.
View of how it looks from bottom up. 3 screws hold it the cabinet and one long bolt anchors it and the "handle." The slide has a notch that shows how it lines up with the handle. 4 bolts connect the slide to the main part.
A view of one of the bolts:
From top to bottom:
Screw bolt with integrated star washer
(ignore the spring washer, I don't think it was actually part of the original assembly, maybe I'm wrong)
Main part
Washer
Small circle part that goes into the slide
Slide
Washer
Lock nut
Bottom to top:
Bolt
Washer with notched square
(cabinet would go here)
Lock bar assembly
Washer( in photo it is above the handle, should be here)
Washer/spacer that has a lip that goes into the handle
nut
I had it setup as in the pictures but the handle wobbled a little. (still worked) I reassembled it as in the text and it works perfectly. Good luck
This page was printed from https://pinside.com/pinball/forum/topic/bally-82-lockdown-reassembly-help and we tried optimising it for printing. Some page elements may have been deliberately hidden.
