Thanks… I wasn’t sure if I was doing the jumping correctly or not?
Just to confirm: like I show in the diagram with the red lines indicating the jumpers.
So if I jump the wires I numbered in red:
#1 If working after jumping then there’s an issue with the Reset Relay (switch being closed?), and I should look at wire #89 or the switch itself? If machine is still not working then test jumper #2.
#2 If working after jumping then there’s an issue with the Tilt Relay (switch being closed?), and I should look at wire #89 or the wire between the Tilt Relay and Game Over (which isn’t numbered?) or the switch itself? If not working then test jumper #3.
#3 If working after jumping then there’s an issue with the Reset Relay (switch being closed?), and I should look at the wire between the Tilt Relay switch (which isn’t numbered?) or the switch itself? If not working then… ???
If I understand that correctly, I will test those today and report back.
As a side note: I know most of the tilt system isn’t working already, the Tilt Bob and Slam Tilt do not work, so would I be correct to start thinking that could be the issue at this point? If I do find the machine works after jumping the Tilt Relay #2, then I would assume my next job would be to look at that entire Tilt system?
Thanks for hanging in there, I’m new to these old machines and am slowly learning how to read schematics.
I was also curious about the wire between the Tilt Relay and Game Over Relay switch that doesn’t have a number on the schematic? Should I assume it’s stays wire #89 since there’s no indication?
