(Topic ID: 277585)
Red Baron tech question
By BBC
2 years ago
  • 10 posts
  • 5 Pinsiders participating
  • Latest reply 5 months ago by HowardR
#1 2 years ago
Hi, I have a Chicago coin Red Baron. Last problem to fix is the game over lights. Game plays fine and ends at the proper time, but the game over lights behind the backglass will not light. I looked at the game over relay and that is fine. Any other ideas where I can look? Bulbs are good so. Thank for the ideas!!!
#2 2 years ago
Inspect and diagnose this circuit with Alligator clip jumper wires
http://www.planetimming.com/Pinball/troubleshooting/EM%20Troubleshooting.pdf
http://www.pinrepair.com/em/index3.htm#features
For a switch to work 3 things are necessary:
1) When open, there should be a small space between the contact points (duh)
2) When closing, the long blade's contact point should push the short blade's contact point enough to move the short blade
3) The contact points should be clean, which they usually will be if #2 is happening
#3 2 years ago
Quoted from BBC:
Test the socket itself by jumping it to a known good one.
#4 2 years ago
Thanks guys for the ideas. I especially appreciate the jumper idea. I always worry about jumping things, because I don’t want to mess things up more.
The problem is fixed and I will document how I tracked it down for future reference.
I jumped from a working light to the non working light. It worked. So I jumped from the game over same colored wire to the non working light and that worked also, so something between the game over relay and the light was causing it not to work. I went to the connectors between the body and head. Found the same colored wire in the bundle and found a loose connection in the connector.
Thanks again for the help. Brian.
#5 2 years ago
Quoted from BBC:
Well done BBC !! I couldn't have said it better.
3 weeks later
#6 2 years ago
I got it there was a bad connection on the NC tilt relay. thank you so much for the help!
2 years later
#7 5 months ago
Thanks!!! A slight switch adjustment and all perfect. Any tips for future in locating a circuit on schematic in the machine ? Seems like my biggest challenge.
#8 5 months ago
Quoted from ahgross:
That depends on what you're looking for. For example to find the circuit for a coil, you can usually find that coil's location on the legend on the schematic. For example, the Chicago Coin Red Baron legend is on the schematic at L24.
#9 5 months ago
Quoted from HowardR:
How about switches?
#10 5 months ago
How about switches?
Can you give an example?
Cabinet Parts
Cabinet parts
The Pinball Scientist
Other
$ 5.95
Protection
$ 259.99
Toppers
Playfield - Plastics
Gameroom Mods
Plastics
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/red-baron-tech-question and we tried optimising it for printing. Some page elements may have been deliberately hidden.
