(Topic ID: 296926)
Williams High Speed
By Otatts
2 years ago
  • 32 posts
  • 5 Pinsiders participating
  • Latest reply 2 years ago by Otatts
#1 2 years ago
Hi everyone. This is my first time posting but I’ve been lurking on the forum reading up on problem solving and I have to say this is a great forum for info and advice, so thank you to all for your wisdom as it’s helped me a lot.
We have a family heirloom in the shape of an original HIGH SPEED Williams pinball. It’s been in our family now for at least 30 years however it’s been sitting dormant for at least 10. It had an issue and was never resolved and sat in the corner since.
My daughter (3) has just shown an interest in it so I thought I’d try getting it going!
Through this forum is found the battery case was fault (dirty) and have rectified that issue and everything seems to be working fine except when I hit start it just sets off the bumpers.
After cleaning the battery case I put it in free play mode to get it out of the ‘adjust failure’ mode and it seemed to fix it except for this start button/solenoid issue.
I just turned free play off but it’s still the same. Am I stuck in a test setting??
Any ideas?
Cheers Owen
Photo is just for photos sake
B2E4CB7A-B403-4EC7-A236-ACE71501B38E (resized).jpegB2E4CB7A-B403-4EC7-A236-ACE71501B38E (resized).jpeg
#2 2 years ago
Quoted from Otatts:
All of them or just one?
Any evidence of alkaline leakage near the battery holder?
#3 2 years ago
Quoted from YeOldPinPlayer:
The middle battery had some corrosion on the negative terminal. I hit it with some sand paper to clean up the terminal and I now have even readings on the meter for all 3 (new) batteries.
Multiple solenoids fire when hitting the start button. Seems like it’s all the kickback solenoids (ramps top and bottom and the left side kickback) it fires them all in sequence twice then the start button does nothing.
This is the battery in question. The others were fine
#4 2 years ago
The adjust failure error you were getting is because the batteries were dead or there was an issue with the batteries and the game was losing the settings as a result.
If the coils are firing when you hit start (not when you immediately turn on the game) then it's probably the game searching for the balls as it does not detect all of them in the trough, so it thinks some might be stuck in the game and is trying to pop them loose. The game will also not start if it doesn't recognize the balls are there.
If the game is on free play, make sure you have all 3 balls in the game. If you do, you will need to put the game in switch test to make sure the switches in the trough are recognizing the balls.
#5 2 years ago
Oh!! I think there’s only one ball in there. I’ll give it a try with the others
Thanks grantopia !
#6 2 years ago
Balls rust so probably time for new ones. I like ballbaron.com but there are probably local suppliers.
#7 2 years ago
Yeah it turns out the other balls went missing and the one left is starting to rust a little so I was going to get a new set. I don’t want it tearing up the play field
There’s a pinball supplier not far from my house
#8 2 years ago
Quoted from Otatts:
Thanks grantopia !
Nice! Get all 3 loaded up and then see what happens! Hopefully you will be good to go!
#9 2 years ago
So I put 3 new balls in and it works!!
Thanks @grantopia!
I still have a couple bits and bobs to fix but the main one is the solenoid that kicks the ball to the plunger shoot isn’t operating.
I tested it with a multimeter and it seems to read the same as the other solenoids so maybe a switch? A fuse?
Any ideas?
Photo: this guy
Cheers O
#10 2 years ago
Quoted from Otatts:
Thanks grantopia!
Any ideas?
Photo: this guy
Cheers O
Test the red wire on the coil for DC voltage.
#11 2 years ago
Awesome news! That coil in the picture looks pretty suspect...lots of things sticking out of it, and it's hard to tell in your picture but it looks like one of the windings could be grounding out to the bracket. What did you test with the multimeter? There are a few things to check...voltage as GRUMPY mentioned, ohms across the coil lugs, you can ground the coil to see if it fires and also the transistor on the board.
What is your experience and comfort level with working on games? That will help with how much guidance we need to provide.
#12 2 years ago
I would say extreme novice at best grantopia but I am enthusiastic. All advice is taken then googled on how to do it. I got 3 or .3 ohms resistance on all coils I tested.
Can you cross the terminals to fire the solenoid?
I tried that with the switch but nothing happened.
I’ve noticed the ‘hype’ music for multi ball doesn’t turn off once the ball is out of play so I’m guessing there’s a faulty switch at work here?
#13 2 years ago
0.3 ohms is too low and indicates a bad coil. There is a chart here that lists many coils and their expected resistance values: https://www.flippers.com/coil-resistance.html
#14 2 years ago
YeOldPinPlayer thanks for that.
I had a look at the chart. Found the coil and retested it making sure I had good contact and it’s measuring 4.3 ohms which is pretty bang on for the 23-800 coil
If I short the terminals will it fire the coil or am I going to do damage doing that?
Coil seems ok. Starting to think it’s. A switch
#15 2 years ago
So I looked up how to test switches and it said the switch should read 0 resistance while activated and the switch next to that coil did.
However the one next to it for the second ball in line did not! It was kind of all over the place. Tested them both again and got the same readings. So I’ll have to pull it out and go to the electrical store once this round of Covid lockdowns are over
Hopefully this does it
#16 2 years ago
Yes, do not short the lugs on the coil, that will damage the coil and potentially the game.
Do you have the manual for the game? The game is in free play, and you are just hitting start to start a game, right?
Does the game music begin and the game looks like it will begin to score (showing you are on ball one, etc.)? If the game is starting, I would think all 3 switches in the trough are working fine. If you have the manual, look at how to put the game in test mode. You can cycle through the tests and get to the coil test and it will fire all the coils in order. Run that and see what happens. There is also a switch test and you should see all 3 switches active. If you don't have the manual, just google up high speed pinball manual, and you should find a IPDB link that will have a free download of the manual in PDF form,
Run those two tests first and see if the coil fires in test and report back.
#17 2 years ago
Thanks grantopia ill have a look tomorrow.
Pretty sure we don’t have the manual so I’ll look it up online
Thanks for your advice
#18 2 years ago
Quoted from Otatts:
https://www.ipdb.org/machine.cgi?id=1176
Can download one from there.
I think it's number 02 in the test. If it doesn't work in the test you could have a failed transistor Q25.
#19 2 years ago
Wow that’s awesome YeOldPinPlayer ! Thank you! I’ll print that out so I have a hard copy
Made a stainless steel bracket for the traffic lights at the bottom of the ramp as they were sagging and the ball was hitting it some times and stopping it going up the ramp. Same with the clear plastic cover over the ramp. Got more clearance now and had a game and got back into the groove a little. Feeling more like the pinball of old now!
Still a few more little glitches to fix but we’re getting there
#20 2 years ago
Ok so I ran the solenoid test and number 2 doesn’t fire.
YeOldPinPlayer is the transistor the little guy between the terminals of the solenoid?
#21 2 years ago
That would be a generic diode.
The Q25 driver transistor should be in the head on the lower left of the MPU -- between plugs 1J11 and 1J12.
-mof
#22 2 years ago
Quoted from Otatts:
No, that's a diode. As mof mentioned, Q25 will be on your main board as shown on page 51 in the manual.
Bad transistor isn't the only possibility though. Do you have power at the coil lugs? Have you checked the fuses? (other coils would also be not working if a fuse were burnt out.)
If you need more details on checking anything please ask. We all started somewhere.
If you disconnect anything on the board take lots of pictures and label stuff so you can get it back in the right spot.
#23 2 years ago
Ah right O. I’ll take a look. Any way to test the transistor?
All the other solenoids seem to be working it’s just that one that’s not playing fair
Thanks YeOldPinPlayer mof
#24 2 years ago
Yep, as mentioned above you can definitely test the transistor, but rule out a few things first. I would make sure as mentioned you have voltage at the coil. Then (game off) measure the ohms across the lugs, and then compare to another coil that is the same part number, such as coil 3. Make sure all the wiring is soldered on the coil and the diode is attached and doesn't look broken. After that we can move into checking the wiring and grounding out the coil and transistor to isolate the issue. This is a pretty common issue so we will get you going again.
#25 2 years ago
grantopia how do you test voltage to the coil? I’ve already done an ohm resistance check and the coil meets spec measurements as outlined in the manual
Sorry for the questions about the obvious but electronic problem solving is new to me
Cheers O
#26 2 years ago
DMM set to DC volts. Black lead stuck under the ground braid. Turn on power to pin and use red lead to test the coil lugs. Power on (28-34 volts) both lugs means good good power and a good coil. Power on one lug means good power and a bad coil. No power on neither lug means no power, look for a broken wire connection on the red wires.
#27 2 years ago
Quoted from Otatts:
Cheers O
GRUMPY beat me to it! And no worries - we all started somewhere, it will come together.
3 weeks later
#28 2 years ago
grantopia GRUMPY
Sorry it’s been a while. Been battling repeated lockdowns and work over this last few months.
I had a crack at measuring voltage but it was super hard to get any consistent reading on ANY of the coils except the 3 pin coils. I haven’t gone back to it yet as my MM ran out of batteries ‍♂️
On another topic I’ve notice something strange with the background music. It’s either on and doesn’t stop no matter what or it’s off and never comes back on unless you switch the pinball off then back on again.
Anyways I’ll endeavor to replace the MM batteries and have other go
Cheers O
#29 2 years ago
Quoted from Otatts:
Sounds like there is no voltage on the coil, but change the batteries in your DMM first to make sure it isn't the batteries.
#30 2 years ago
Ok so the coil in question is reading about 4.7 volts. The other coils of the same caliber AE 23-800 (3 mushroom bumper coils up the top of the playing field) are measuring about 8-9 volts but one is also down around 5 but as far as I can tell that one still works
I guess I should just replace them anyway right as they’re reading so low
#31 2 years ago
Quoted from GRUMPY:
Quoted from Otatts:
No so fast. If you're not getting 28-30 volts at any coil using GRUMPY 's test method your machine is dead and no coils work. Maybe take a picture of your meter showing how it's set when you do the test and we can verify it's set correctly?
#32 2 years ago
YeOldPinPlayer i’ve had it on this setting
I’ve been putting the negative lead to the center of the solenoid (the bottom of the rod) and the other through the hole at the positive terminal
I couldn’t take a pic while getting a reading as that would require 3 arms :/
73E4A5C0-3C84-4948-8312-0AC371C30328 (resized).jpeg73E4A5C0-3C84-4948-8312-0AC371C30328 (resized).jpeg
4,995 (OBO)
Dunakeszi
RobTune
$ 69.00
Pinball Pimp
$ 95.00
Pinball Mod Co.
$ 54.99
Gweem's Mods
$ 12.00
Metal-Mods
RobTune
$ 18.00
$ 35.99
Fort Lauderdale, FL
Red Oak, TX
$ 27.95
$ 53.99
6,500
Orange, CA
This page was printed from https://pinside.com/pinball/forum/topic/williams-high-speed-3 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
