i forgot to mention. same goes for cross hatch style flipper cabinet switches and leaf switches that have smaller circle contacts. the reason sopranos, HRC, Sharkeys shootout, Elvis, RBION, LOTR and other early sterns (later sega) have weak flippers is because of the cross hatch contacts they used on cabinet flipper switches. when i bought those early sterns NIB i instantly switched them out with williams cabinet flipper switches and they never get weak like wet noodles, no matter if you play game after game. the lotr at this past chicago expo was mine and i was asked more than once how both flippers were strong enough to hit the ring even after non stop gameplay.
cpu controlled has nothing to do with it, thats why EOS switches have to be fresh and properly gapped as well.
its about current being applied.
again, with an opto its all or nothing.
with leaf switches it matters how much pressure you apply, what size the contacts are on cab switches and EOS, and how clean those contacts are and how far the gap is.
how about light sockets that are cpu controlled? the lights' brightness is based on the analog socket itself and how clean it is, how the connection is and so fourth.
