Quoted from Chrisbee:Looks like a few NEW wires added, Is that a plastic coated blue wire going to the credit unit?
Doubtful, unless they color matched and snuck the wire in under the vintage, dirty waxed linen lacing. Remember, this is probably the "zero position replay switch", which likely carried 110v and coincidentally was blue in many machines of this vintage.
Regarding the original question, the first thing I would look for is to see if the previous owner simply cut or desoldered the wire to the coil. If not, check the start (S) relay or look on your schematics to see see what else is on that circuit. Motor 2C is another likely culprit.
Before you do that, you may want to get introspective and assess your chances of fixing this minor problem that doesn't affect game play with the chances of mucking something up. You will likely end up just setting your game up for free play in another manner anyway.
The other thing to consider is that prior to selling a machine, OPs often severely hacked up the wiring involved in the coin and credit circuitry to keep the machine from showing back up on a competing route.
Todd
Team EM.
