See attached picture of my Victory Derby motor board.motor assembly for pinside (resized).jpg
There are three solenoids on this board. I need some help identifying the coil numbers of each. The schematic provides NO help.
(1) I believe the two coils circled in blue should be the same value--not sure. Can someone advise? What are the correct coil numbers?
(2) The solenoid circled in red. What is the correct coil number?
(3) The bright aluminum disc circled in yellow (next to the hard rubber washer) is that correct for this machine? It looks fabricated. Obviously the washer is incorrect.
(4) Has anybody got experience with this board? Id like a little guidance when I reassemble. All the other components of this machine are relatively straight forward.
(5) Can anyone help in identifying the other coils in this machine (relays and solenoids)? The markings are all but toasted.
Thanks to anyone who can assist. I'm a pin guy, but I'm learning!
Bob
Bowling Green Ky
