(Topic ID: 188008)
United Star Slugger 1956 pitch and bat
By FredWJensen
6 years ago
    #1 6 years ago
    Old relays and contact switches, sometimes does not move runners to home after Home run but only to 3rd.
    Sometimes runs are not tallied properly have mechanical disks for score. Maybe needs cleaning?
    Anyone familiar with this 1950's electro mechanical technology will be helpfull, thanks
    #2 6 years ago
    If you want to sell the machine, message me
    #3 6 years ago
    Quoted from FredWJensen:
    Do you have a schematic? Have you cleaned the switches and cleaned and lubed the steppers?
    #4 6 years ago
    Quoted from drsfmd:
    a little spray cleaning with Napthta,
    what are steppers?
    I have a schematic
    #5 6 years ago
    Quoted from kovalski3:
    This guy has one for sale 5200 dollars and in Canada, I almost bought it but found one closer to me
    http://www.pinballowners.com/pinball/8134/2/2/Star-Slugger-pinball.html
    #6 6 years ago
    Yes, Star Slugger is the Cadillac of Baseball machines..
    Maybe you can search for someone in your area to show
    you a couple things on cleaning and going through the
    mechanics of your machine. It really should be fully gone
    through for it to work smoothly and properly.. (T)
    #7 6 years ago
    Mine always runs great when I play it regularly. When I let it sit for a while, like I did recently, the scoring reels don't always turn properly or don't reset to zero. Usually a little lube will fix it.
    The problem is that I just don't have the time to keep up with it these days.
    #8 6 years ago
    the biggest problem is that when a home run is hit the runner only goes to 3rd base.
    #9 6 years ago
    If the Men-Run-the-Bases motor is running slow, this will happen.
    There's a small tail on the motor's armature that pulls in when energized,
    and out when the motor stops running. Just a couple drops of light weight
    oil on that tail could help this out..
    When a Home Run is hit, the Home Run Relay does energize, right?
    #10 6 years ago
    yes the relay activates. Oiled , no change
    #11 6 years ago
    Bump.
    I'll be interested in hearing how this works out for you, Fred.
    Mine, coincidentally, had just started giving an occasional home run for a triple, a triple for a double etc. I'll get back to looking at it next week.
    #12 6 years ago
    Bump
    Hmm
    Maybe move this topic to the p&b thread.
    This page was printed from https://pinside.com/pinball/forum/topic/united-star-slugger-1956-pitch-and-bat and we tried optimising it for printing. Some page elements may have been deliberately hidden.
