I removed my original JP power supply board when the HV leg appeared to have failed (for the DMD). I replaced with a Rottendog board as this seemed the shortest path to confirming my issue was with the DMD or the PS itself, and getting the machine back into playing condition. All is well.
As I have some time available now, I thought it might be a fun little project to try and diagnose and repair the old board. No harm, no foul if I fail.
Questions:
1. What's the best method to get power to this board to test my repairs? I'd much prefer not to have to insert/remove from the JP backbox until I am confident the board is functional. Plus, accessibility of the PS behind the backbox door hinge a real pain in the butt.
Is it reasonable/feasible to make an extension cable (~15ft to my bench), and connect the 4 wires coming off the transformer via the nearby Molex connector? These are pretty hefty wires (2x White, 2x Yellow); what AWG and Pin diameter here?
2. Any other connections required to confirm output voltages from the remote PS Board?
Any suggestions or cautions?
