Hello all,
So I’ve run into an issue with my machine “Time Warp”.
When I play a game and the ball falls into the place behind the flippers, the ball will stay there and the selonoid will not attempt to push the ball. It’s odd because when starting a game the selonoid will push the ball into play.
Here’s what I’ve done so far:
1) Checked all fuses and replaced any burnt ones
2) Run the solonoid test function to make sure all are working correctly (they are)
3) Checked the piece that the ball falls on when you lose it. The weight of the ball should be able to send a signal to the solonoid to push it back into play. I also adjusted this to make sure it wasn’t too low or too high. I also made sure to check that all connections are still soldered properly.
I hope this information can is useful in diagnosing an issue. I can provide pictures as well. Thank you!
