Hey gang,
Recently bought a ToM that needs some work. I've gotten some things sorted out, but need some help with a couple things.
The first issue is the wiring for the Trunk Lamp. The wires are completely disconnected under the playfield. There are 2 sets of yellow/grey and red/green wires coming from the connector. Close by the trunk mechanism I found one set of these colored wires, which I assume the shorter set connects to, but where does the longer set of wires connect to under the playfield?
Also near the trunk mechanism there is a connector for which I cannot figure out where it connects to. From trying to look at some pictures I am thinking this connecter just doesn't have another side. Is that correct? What is this connector?
Finally, there is a connector laying on the bottom front of the cabinet near the coin door. There is a solid purple wire disconnected from the connector. 2 questions: where does the solid purple wire go in this connector, and where does this connector connect to? I cannot figure that out.
Thank you very much for all of your help!!!!!!
